2000 7.3 werid problem with a miss - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-28-2013, 04:55 AM Thread Starter
Thumbs down 2000 7.3 werid problem with a miss
Hello i have a 2000 7.3 its got 5" exhaust and a tuner im not sure on what brand of tuner.
When i start it in the morning even if i plug it in it will have like a skip or a miss at idle and even if i let it warm all the way up and take off you can feel it, in less you give it more pedal then it runs like a champ. also i found that if im driving it and stop and let it idle for 10 to 15 mins it will start doing it again till it clears it self out or somthing.
i did the whole fuel seal rebuild thinking maybe it was sucking air some where and that didnt help at all, i was reading on here somone changed there oil and it went away for a bit then came back. it drives me nuts
if anyone knows where i should start checking stuff that would be great this is my first ford truck ive always had dodges and kinda missing my dodge now
i have a gopro so if i need video just let me know thanks
dkanderson is offline
post #2 of 6 Old 10-28-2013, 11:56 AM Thread Starter
bump taking it tomorrow to get a buzz test
post #3 of 6 Old 10-28-2013, 12:00 PM
Raul@Stealth Automotive's Avatar
can you tune the truck back to stock?
Raul@Stealth Automotive is offline
post #4 of 6 Old 10-28-2013, 12:14 PM Thread Starter
yeah i can turn the tuner off
post #5 of 6 Old 10-29-2013, 10:42 AM Thread Starter
took it n got a buzz test done they said it was saying all injectors were bad and the guy said theres no way that all 8 are bad, so he said it could be the wiring under the valve cover or a Injector Driver Module he said most the time when its the wiring its only 1 side and he said it would take 2 hours to find out if its wiring or the module and said it was 900 bucks for the module and i just looked online and i can get one for around 300
post #6 of 6 Old 11-02-2013, 08:03 AM
blue99stroker's Avatar
Quoted: 280 Post(s)
the harnesses are 40 bucks a piece from dieselorings.
will take you two and a half hours to replace both of them.
as far the the idm goes, you can find them on ebay for 100 bucks.
mine as well do the 140v mod to it as well.
any idm works from 94-03.
try replaces the cps as well.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
