Battery & Alternator Drain - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-26-2013, 12:27 PM Thread Starter
I have a 2001 F350 that I have been having some issues with lately, specifically with the batteries being drawn down when I don't use the truck frequently. After I jump the truck or charge the batteries back up and start the truck, I am only getting about 12.3 volts at each battery and about the same at the alternator. The alternator is new, within the last month, and the batteries check out as good. Anyone have any thoughts on what might be the issue, with first the drawn down batteries and second with the alternator not charging? Could it be a bad cable between the alternator and battery or could it be bad cables off the batteries, I have heard that the battery cables on the 7.3 powerstroke can go bad and possibly be causing my problems. Thank you in advance and any and all help is greatly appreciated.
h2orider9 is offline
post #2 of 3 Old 10-27-2013, 01:46 PM
Quoted: 6 Post(s)
I'm having the same exact issue on a 99
1999 F-350 ECSB ZF6 4x4 Halfbreed:
Mods:
PHP Pheonix 6-Position Chip
Glowshift gauges (boost/egts/oil psi/fuel psi/oil temp/coolant temp/voltage
DIY 6637 Intake
5" Diamond Eye exhaust
05+ Harley Davidson Headlights
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
DIY fuel system with regulated return
and saving to build a mid 500hp rig.
stroker0920 is offline
post #3 of 3 Old 11-01-2013, 09:45 PM
Quoted: 6 Post(s)
By the way. My issue was my glow plug relay was constantly drawing 80 amps from my alternator when the key was on. Check the amps at the relay power wire while the key is on
Mods:
DIY 6637 Intake
55w 5000K HIDs
Future Mods:
Shocker horns
SRP1.1
Irate turbo setup
S366
