7.3 just shut off - Ford Powerstroke Diesel Forum
post #1 of 14 Old 10-25-2013, 03:16 AM Thread Starter
7.3 just shut off
1999 7.3 diesel just shut off while driving to work still had lights and was able to crank the engine but would not start. Having it towed. Newbe to site
DonP53 is offline
post #2 of 14 Old 10-25-2013, 05:15 AM
timmyboy76's Avatar
get yourself a new CPS..(cam positioner sensor) from the dealership. The ones' from the autostore are junk.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 14 Old 10-25-2013, 05:59 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Well, of course, there are literally Dozens of things it could be....
In a '99 the quick CPS test is to watch the Tach while cranking on the Starter. If it moves up slightly, the CPS is doing it's job. You can check for things like Fuel Delivery (are you below 1/4 tank?), and blown fuses (do you get a WTS light when you first roll-on the key?) before you pay for a tow. Then, you would want to get it on the right scanner to monitor the sensors to see what might be going wrong (you need a professional scanner NOT one of the cheap ones the Auto Parts Stores use).
NoRalPh is offline
post #4 of 14 Old 10-27-2013, 03:03 AM Thread Starter
NoRalphs Gallery Hall and Tommyboy76. Thanks for your replies not sure what the problem is yet but had to tow it to the Ford dealer ship will find out Monday as they where to busy to get it till then.
DonP53 is offline
post #5 of 14 Old 10-27-2013, 07:44 PM
I doubt its the CPS. CPS failures are usually one miss that kills the engine and you can immediately restart it.
Sounds more like an oil/fuel delivery issue. Check fuel pressure, ICP, and IPR duty cycle. Early bet is IPR.
A/Ox3 is offline
post #6 of 14 Old 11-10-2016, 02:22 AM
Hello Gents
I have a problem with our van, 7,3l I have the same symptoms, Just stops after starting, and as soon as it gets warn doesn't start at all. The problem is I live in Romania and there is no shop to work on a vehicle like this one. No program, no computer hook up. Does any one of you have the patience to point out some things I could start from? I m not stupid I m pretty handy with tools, I can work on a car, I do not have a good vocabulary to understand all the terms but I do have some good american friends here that will help me with this.
thank you so much
benilariu is offline
post #7 of 14 Old 11-10-2016, 06:10 AM
Quoted: 157 Post(s)
benilariu - start your own thread, be sure to include information on your van (year, mileage, any mods, maybe some repair history).
In your situation, I think it's very important for you to get your own scanner that will allow you do repair & maintain your van. The most complete tool you can get would be the AutoEnginuity (with the Ford Enhanced package) for $350 US that you run on a Windows computer. You can get the most important information for a lot less with an App based tool. Read through this -> Ford SuperDuty Diagnosis on the Cheap
With the right scanner you could monitor the sensors to see what's going on as it stops running (the Hi Pressure Oil sensors in particular) and get codes that the computer generates when things go wrong.
This can be as simple as low oil level in the engine (check the dipstick) or fuel delivery because of a clogged filter, bad pump, or even a cracked pick-up in the fuel tank (add fuel if you're 1/4 tank or lower).
It can be Many other things too of course
Check that easy stuff, start your own thread, include new info including what you've found.
NoRalPh is offline
post #8 of 14 Old 11-13-2016, 05:58 AM
Quoted: 5 Post(s)
I agree, you need a good scan tool. However AutoEnginuity is expensive. Get on Amazon order an ELM327 with drivers disk and go to ForScan.org and download their free software. I've been using it on my pickup for a while now and it works great and gives me all the options everyone else says AutoEnginuity gives them for only $15 for the cable
bgmoore10 is offline
post #9 of 14 Old 11-13-2016, 06:46 AM
Quoted: 157 Post(s)
You'll see in my post above I linked to the thread where the ForScan, and other "App based", scanners are tested & evaluated along with my advice that you'll get most of the important info you'd get from the AE for a lot less money.
But if you think the ForScan does everything the AE does for that money you're kidding yourself
NoRalPh is offline
post #10 of 14 Old 11-13-2016, 07:25 AM
Quoted: 5 Post(s)
I don't think I am. Give me a example of something you can do on AE that you can't on FS.
