Air only coming out front vent? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-23-2013, 01:36 PM Thread Starter
I've searched and found similar problems, but nobody with the same problem. My problem is air is stuck on the front vents, not the defrost vent that seems to be very common. I tried turning the a/c on and still blows out the front face vent. I have searched for a vacuum leak and so far cant find anything. I tracked the vacuum lines into the cab and disconnected a few. I don't even feel air coming out.
2003 F250 7.3 CC SB FX4
TS Chip Tuned by Tony Wildman
4" MBRP Turbo Back Straight Pipe
Driven Diesel Regulated Return
International Bellowed Up-pipes
K&N Intake W/ 6637
Transgo Shift Kit
ATS Ported Turbo Housing
Wicked Wheel 2
EBPV Delete Pedestal-High Flow Outlet
3 Gauge Pillar Pod
Viper Remote Start w/Turbo Timer
potbss is offline
post #2 of 9 Old 10-23-2013, 01:39 PM
66Bronco's Avatar
Check the blend door actuator on the heater box under the dash. They are electronic and can stick open or shut. Pretty cheap, most parts houses carry them.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #3 of 9 Old 10-23-2013, 02:22 PM Thread Starter
Is that located under the glove box?
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #4 of 9 Old 10-23-2013, 02:28 PM
Heavy_GD's Avatar
Quoted: 1497 Post(s)
Feedback Score: 3 reviews
Heavy_GD is offline
post #5 of 9 Old 10-23-2013, 03:08 PM Thread Starter
The temperature works fine, a/c is cold and hot air works fine. Does that part also control the vents from switching back and forth?
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #6 of 9 Old 10-25-2013, 07:45 AM Thread Starter
Did some more looking and found air coming from this area. Not sure if this is normal.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #7 of 9 Old 10-25-2013, 07:46 AM Thread Starter
The air is coming from between the silver pluming and black plastic, near the head of the screwdriver.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #8 of 9 Old 10-25-2013, 08:54 AM Thread Starter
So I plugged a vacuum line next to the hub control solenoid and after doing that I can now switch the vent to the floor. The defrost is still not working though. The pump turn off now that i have that vacuum line plugged.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
post #9 of 9 Old 10-25-2013, 08:58 AM Thread Starter
Also the actuator now works since that line is plugged. any help is appreciated.
K&N Intake W/ 6637
Transgo Shift Kit
Wicked Wheel 2
3 Gauge Pillar Pod
potbss is offline
