Glow Plug Relay Question - Ford Powerstroke Diesel Forum
post #1 of 26 Old 11-02-2006, 02:46 AM Thread Starter
Last night I used a test light to check the contacts on the glow plug relay. I found the big post that was hot all the time but the two small posts were also hot all the time. Is this normal. The other big post never got hot so I am assuming I have a bad relay. Is there any other test I can do to verify this before purchasing a new relay? Also where is the best place to purchase a new relay? It is starting to get cold here in PA so I need to remedy this problem ASAP. Thanks for any info regarding this problem.
2000 F-250 SD Crew Cab Lariat 183K miles
4" magnaflow exhaust w/ 3.5" DP, DP chip (stock, 40T, 80E, 120R), AFE stage 2 intake, Autometer gauges, ITP Diesel AIH delete and Overboost Annihilator, 285/75-16 Hankook Dynapro ATM
Extremesolo is offline
post #2 of 26 Old 11-02-2006, 04:49 AM
Sorry I can't answer your question, but I'm sure someone will be along soon.
Where abouts in Cent. PA?
Any bow hunting for you?
beerhunter is offline
post #3 of 26 Old 11-02-2006, 07:11 AM
Glowplug Relay
Hi,this whisky6,about the glowplug relay if yours looks like a ford starter relay i used a ford starter relay on my 1995 psd for over a year now with no adverse effects yet may not last as long as original,but the reason i used the starter relay was the cost (17.00vs82.00 )at ford parts,i could not see any difference between them,thank,s
WHISKY6 is offline
post #4 of 26 Old 11-02-2006, 11:28 AM
I had the same glow plug problem, but for a different reason, (see my post on this same forum, autotrans puked & wont start). The glowplug relay is hot on both small posts because there is no current flow thru the coil until the PCM provides an "active" low (ground) to complete the circuit from + to -. To test, attach a jumper (use with wire guage same or larger than on post) to ground, test lite should go out & glowplug relay will actuate. You should be able to feel the relay when you touch grounded jumper to post on driver side, then jump into truck & try to start. If relay & glowplug are good, truck should start & the fault is either wiring to PCM or PCM???? Marc may be able to shed some lite on PCM failures.
Frank is offline
post #5 of 26 Old 11-02-2006, 04:35 PM
Whiskey, be VERY carefull using a relay not designed for the function you are using it for. If too much, or too little amprage than a relay is designed to work with, you can cause major problems!!
mschn99 is offline
post #6 of 26 Old 11-02-2006, 05:49 PM
same problem
same problem here where do the two small wires go?
karbo
Karbo is offline
post #7 of 26 Old 11-02-2006, 06:03 PM
ignition wire and PCM controlled ground (timed)
mschn99 is offline
post #8 of 26 Old 11-08-2006, 04:50 PM
Thumbs up
99 PSD 7.3 I went through the same deal last week. I checked with a test light, no juice going through. I checked around for prices and NAPA had the best deal. $53.00. The next morning we had a cold spell down to 26 deg. Heated up started fine.
markgo8 is offline
post #9 of 26 Old 11-08-2006, 08:54 PM
Powerstroke Techie
djsdiesel's Avatar
To check your glow plug relay use a DVOM put on dc volts. hook positive clamp to one of the big terminals and the negative clamp to other big terminal. with key off you should have battery voltage. with key on the dvom should read less than .02 volts. (Ford Spec.). Depending on temperature glow plugs can stay on for up to 2 min. Ford relays are nitrogen filled others are not. Supposed to last longer.
djsdiesel is offline
post #10 of 26 Old 09-14-2007, 05:27 AM
Does the .02 below that DJ is refering to come on and then go back to Battery voltage. My First diesel F350/7.3/1997 and felt my relay was a little hot, so hot i could not touch it. Not original two post relay but four post installed.
PUGTRACKER is offline
