trailer wiring harness, help!!! - Ford Powerstroke Diesel Forum
Old 07-16-2008, 03:23 PM
Send a message via MSN to gwilliamson
I went to hook up my newly wired gooseneck to my ford yesterday and all the lights check out on the trailer execpt stop turn on the pass side. i put a tester on that function and it checked out on the trailer but not the truck. i cleaned up the factory pig tail connector where the female plug goes into the harness up by the drivers frame rail forward to the rear bumper.... is there a fuse or something i'm missing because i have cleaned every connector i could find.
Old 07-16-2008, 03:28 PM
Other vehicle is an F250
I don't know if there are any fuses, but the exact thing happened to my son's DoddieMax and it was fuses. Check 'em all!
Old 07-16-2008, 03:36 PM
One more plug to check, the plug on the end of the truck actually comes apart in two pieces, remove the four small screws that hold the plug into the bracket and you should be able to remove it in two pieces/connections. Clean that and electrically check to see if you have power at the plug you just pulled apart, put some dielectric grease in there as well when you put it back together.
If I remember correctly there is also plugs right near the trailer hitch and spare tire, pull those apart and check those as well for power.
If you don't have a power at the plug I would work your way up to the front of the truck checking for power at each plug, and as said before check all fuses.
Old 07-16-2008, 04:16 PM
Illiana Chapter Director
Don't know what year your truck is, but fuse #6 under the dash is for trailer tow turn/stop relay. This info is out of a 2004 Owners Manual. Hope it helps and you get it fixed.
Old 07-16-2008, 06:00 PM
thanks guys, yeah i checked that one by the spare.... haven't got to fuses yet cuz i didn't know which one to check. thanks guys and i will report back
Old 07-16-2008, 06:21 PM
Try turning on the pass. turn signal then with a test light go to the trailer plug on the truck and touch the connection for pass stop/turn. I had to do this last week and ended up being a 20amp mini fuse under the hood.
Old 07-21-2008, 06:55 PM
^^^ what 2005F250 said. Check the under hood fuses. They're in between the air cleaner and the firewall. Some of those fuses are for the power that goes out the plug. The under dash ones are for the truck itself.
Old 07-22-2008, 06:23 AM
yeah thanks guys, i bet it is that fuse... i was wiring the trailer and i followed the wrong diagram (wired it for commercial at first on accident) so i bet i short that fuse. i'm currently on the boat so i can't check it. that will be the first thing i check when i get off.
thanks again guys
Old 07-22-2008, 06:28 AM
yea there is a fuse under the dash pannel and it runs the stop/signal on the harness mine blows all the time im temped to but a bigger fuse in so it will stop but then it might burn the wire if there is a short
Old 08-01-2008, 09:04 PM
it was the 7.5 amp fuse under the hood fuse panel.... inboard side forward....
thanks guys
