not etting fuel to bowl, brand new motorcraft fuel pump - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-19-2013, 05:33 PM Thread Starter
dieselhate's Avatar
ok this is driving me nuts, i finally got my truck back to the house. trying to figure out this no fuel issue.....so i let a friend borrow my truck and he said it ran out of fuel and wouldnt restart. apparently he didnt check the fuel bowl at all and burned out the "on rail" fuel pump......so i bought another one. before i hooked it all up i stuck the sucking end of it into a cup of water and it spurted water everywhere, letting me know the pump itself is good. still no fuel to bowl. also i disconnected the front fuel line of the pump to see if i could get it to spew diesel, nothing. its definitely not getting fuel out of the tank. luckily i have a dump bed and getting to my gas tank is super easy. I took the lift pump from out of the tank and cleaned it very well, there seems to be no restrictions whatsoever with it. still no fuel to bowl.........so here i am folks, dead batteries now, good fuel pump that wont suck fuel, is my lift pump bad?? i put a test light to it and not getting any voltage from either of the two wires. any help is appreciated.
thanks,
sean clark
dieselhate is offline
post #2 of 4 Old 10-19-2013, 05:38 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Lift pump? There is no lift pump....id check for a crack in the pick up straw. Check the bottom of the strainer on the pic up...
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 4 Old 10-19-2013, 05:56 PM Thread Starter
dieselhate's Avatar
ok i checked and theres no crack in the pick up straw. ive got the fuel "pick up" connected but out of the tank. can these go bad?? im not hearing anything from this pick up. im really lost. is there a fuse or something for this thing? relay? ive priced these and really dont wanna buy another one....im sick of throwing parts at this truck already.......
post #4 of 4 Old 10-20-2013, 09:06 AM
Doesn't Even Care
Quoted: 69 Post(s)
You're looking at the fuel level sender connection. The pick up straw just draws the fuel out of the tank when the pump turns on. Maybe the lines and pickup could have a clog in it?
Nick
"The Mistress"
