7.3 cutting out at random - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-19-2013, 05:03 PM Thread Starter
I have a '02 f-250 that's cuts off going down the road. It feels like it cuts off and then right back on. Sometimes it will do it 7-8 times a day and other times it won't do it for weeks. replaced cam position sensor and IPR valve with no change. Also, when I crank the truck, the radio and windows won't work for a minute or two. Could these problems be related??
70white is offline
post #2 of 5 Old 10-19-2013, 05:20 PM
BrodieBiking's Avatar
Nope, im sure it totally different. I still have the radio / window issue, but its very intermittent. Do you have an after market deck? (a temporary but violent fix is to hit the top of the dashboard on top of the deck... haha! it sounds bad but it works!
The throttle cut-out on mine was actually a throttle position wire thats been running against metal and eventually shorted out. Surprisingly the wire was just open, it had no protection from rubbing, so that may be the case for you. Under the front driver side fender well. It was actually good timing for me though, I just pulled up beside my local auto shop and the throttle completely died! haha.
Hope this helps.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #3 of 5 Old 10-19-2013, 05:27 PM Thread Starter
I'll look for tps wires in the morning. The radio is the stock unit. Thanks
70white is offline
post #4 of 5 Old 10-19-2013, 06:38 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
some cps's are known to be bad right out of the box.
delphi cps or borg warner are the way to go.
although borg warner cps has wiper issues on some trucks.
delphi can be found on amazon and BW at oreilys
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #5 of 5 Old 10-24-2013, 10:44 AM
Lilz9286's Avatar
I have the same issue. So if you find out what is causing the problem let me know. Its getting a little dangerous.
Lilz9286 is offline
