Knocking in Park and Nuetral - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-18-2013, 03:15 PM Thread Starter
jpalma's Avatar
Leaving the parts store today noticed my truck was knocking sitting at idle in park. Cant pin point where the noise is coming from. It is only noticeable when in park and neutral. When I shift through neutral to drive it knocks for a second then goes away. I looked it up and I am not showing any codes. I read maybe inj no 8 but that should be showing a code correct? Torque converter? Flywheel?
Really bothering me and want to know its not something serious before winter.
Any ideas?
Thanks
2000 F250 Crew Cab, 366,500miles
,6637,Foil delete, Smoked Cab lights, Bed Liner Rockers, Muff. Delete,08 DIff Cover, 50 Gal Transfer Flow Tank
jpalma is offline
post #2 of 12 Old 10-18-2013, 03:25 PM Thread Starter
jpalma's Avatar
Goes away in park when when I touch the gas pedal at all. I took a video of the sound, I will try and up load it.
jpalma is offline
post #3 of 12 Old 10-18-2013, 03:49 PM
timmyboy76's Avatar
i think your flywheel is about to crack and really make a wracket
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #4 of 12 Old 10-18-2013, 05:59 PM Thread Starter
jpalma's Avatar
Is there a way to tell if it is the torque converter or the flywheel?
jpalma is offline
post #5 of 12 Old 10-20-2013, 07:07 AM
timmyboy76's Avatar
IF flywheel, the noise will get worse to the point, it sounds like, marbles in a can. You can still drive however, but it'll annoy the crap outta you.
post #6 of 12 Old 10-28-2013, 07:44 AM Thread Starter
jpalma's Avatar
Flywheel looks all in one piece I am thinking it is the converter. Making noise like crazy with the inspection plate off.
jpalma is offline
post #7 of 12 Old 10-28-2013, 08:40 AM
timmyboy76's Avatar
you cant see the crack. Gotta remove the tranny.
post #8 of 12 Old 11-02-2013, 03:53 PM
BrodieBiking's Avatar
Sounds like the transfer case.
2002 F350 CCLB DRW
ZF6 SWAPPED!
--Southbend 1944-6OFEK
12.5in lift on 24.5's----------3" Body Lift
MBRP Dual 4"--------------Muffler Delete
K&N Intake----------------AFE Spider
Garret GTP38R BB--------- P.I.S. billet wheel
TS 6pos chip--------------NLTD tunes
P.I.S. 200cc/80%--------- P.I.S. IDM
Parrot Asteroid-------Boston Accoustic SR80's
NVX VCW 10”s------------ McIntosh MC431
Warn Manual hubs---------Bed Rails/Air tank
BrodieBiking is offline
post #9 of 12 Old 11-04-2013, 05:55 AM Thread Starter
jpalma's Avatar
It was the Flexplate, was just ripped right off. Since I have the trans off is there any way to tell if torque converter is bad? If mine is on the way out would like to replace now and never do this again.
jpalma is offline
post #10 of 12 Old 11-04-2013, 07:35 AM
Whoops ment to say torque converter in the last post haha
2002 F350 CCLB DRW
ZF6 SWAPPED!
