o/d light flashing po603,po705,po708 and poB45
my o/d light flased once before and I had no drivability issues so read a thread on the problem and it said to clean all connecters and I did. no more light flashing,then about a month ago I went through some shallow water and it started flashing again. So I repeated what I had done before But didn't work this time, I pulled the codes and got a po705 & po708. Ford & others recommended replacing range sensor , so I did but after clearing codes and un hooking battery too., the light was still flashing but with no drivability issues. I pulled the codes again and got po603,po705,po708 & poB45. I've cheacked wiring and plugs nothing noticable. My truck is a 2002 f-250 super duty 7.3 auto crew 4x4 with 68000mi, ANY SOLUTIONS?
THANKS AJ
I strongly suggest you go to a trans shop. Have them run the diagnostics on it. They can do road tests with a computer hooked to your truck. They can pin point the problem. It could be a simple relay or solenoid in the valve body that is bad.
THANKS i'LL TRY TO GET IT IN
