What is this and why is it always running? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-15-2013, 12:39 PM Thread Starter
03ranger30's Avatar
What is this and why is it always running?-imageuploadedbyautoguide1381869486.515193.jpg
I believe this is the vacuum pump but I'm not sure. It runs constantly when the key is in the run position. Whether or not it's supposed to I don't really know, but it's pretty loud, it isn't like that in the other 7.3 we have.
Sent from AutoGuide.com App
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #2 of 4 Old 10-15-2013, 12:49 PM
belz's Avatar
Quoted: 70 Post(s)
Yes it is. Should turn off once vacuum has built up. Mine runs for a little most of the time I turn the key on. Maybe you have a vacuum leak.
Belz
CPA Director
belz is offline
post #3 of 4 Old 10-16-2013, 04:31 AM Thread Starter
03ranger30's Avatar
How would I find a vacuum leak if I had one?
Charlie
post #4 of 4 Old 10-16-2013, 05:12 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
first pull off the line and plug it with your finger, the pump should shut off , if not replace the pump. look under the dash around the heater box and control lines ,they usually leak there. look for loose fitting and dry rotted rubber
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
