Had a problem, but its fixed. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-12-2008, 12:27 PM Thread Starter
lonuf's Avatar
I purchased a 02 F250 2 weeks ago. Got her home and decided to do a buzz test as she has 165000 miles. Found 3 weak.
Called the dealer, worked out a descent deal for them to replace all 8, they pay half and i supplied the injectors. So i was only out of pocket 500. Took it to them as they insisted they do the work (cheaper for them). Got a call when they were done that 1 or more of the new injectors were bad but they did not have the equipment to find out what one's. Kinda sad. But they are a chrysler dealer. So i got it home, hooked up the solus and 2 was week and 1 tossed a p1271 code. Ran like crap under 2k. if i pushed it it was smooth but cruising i could feel a bad miss.
For some reason the injector company sent me 10. They did nto know how this happened but whatever. I had 2 spares and swapped them out this morning and all is well now.
Just figured id share the info. never know when someone sees a 1271 code and doesnt think it can be an injector. I had them install the uvc harness and gaskets so all that was new.
lonuf is offline
post #2 of 4 Old 07-12-2008, 12:42 PM
Ole White
bigwhite7.3stroker's Avatar
WELCOME TO ORG! ! ! and glad to hear you got your rig running right
Looking for 05-07 front end with Harley Lights
bigwhite7.3stroker is offline
post #3 of 4 Old 07-12-2008, 01:02 PM
<<---"Shadow"---
sea71's Avatar
WOW!! Glad all is good now. Bad New injectors!!!
Shane
2011 F250 Crew Cab FX4
STOCK!
sea71 is offline
post #4 of 4 Old 07-12-2008, 01:46 PM Thread Starter
lonuf's Avatar
Sounds like someone put some injectors that failed the test in the wrong box. Who knows. Sucks when you use up your free labor on something your going to re-do the next day.
lonuf is offline
