truck wont start need help quick - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-14-2013, 03:25 PM Thread Starter
truck wont start, lights on dash dont come on, batteries are 1 year old alternator is a month old. i they key and the relay starts to click. Is the ground to the ecu bad? is the chip making the computer not start? whats wrong?
2000 f250
165,000
6inch pro comp lift
37 in toyo
10K HIDís
boost fooler
6 pos chip PHP tunes
4inch straight pipe, dumped
gauges- boost, trans temp, egt
DIY afe intake
Foil Delete
BD thruster turbo
bloom7.3 is offline
post #2 of 2 Old 10-15-2013, 05:59 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
First thing is to carefully check All the fuses. If the WTS light isn't coming on it's an indication the PCM isn't running. Often the fuel heater fuse (#30) blows and this happens.
Is the engine turning over on the starter? If not you could have a bad battery cable or end, bad relay, safety sw, starter, low batteries, ALL KINDS OF THINGS.
Tell us more about what happens when you try to start (but, again, without a WTS light, you're just wasting time and running your batteries down)
NoRalPh is offline
