Steering "Thump" - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-14-2013, 07:14 AM Thread Starter
Steering "Thump"
I was leaving a parking lot yesterday that required going over a large, raised portion of the sidewalk. Afterwards, I heard squeaking. That subsided, but then the steering was making thumping/rubbing sounds.
Symptoms:
If I turn the wheel 25-45 degrees there is a cyclical rubbing/thumping feeling. I can hear it on the driver side and my passenger could feel it on the floorboard.
Troubleshooting:
I've looked for rubbing and contact points
Been under the truck while the wheels were turned back and forth
Greased up the grease points
The only thing I can find is this dent on the steering damper. The dent has obviously been there for a while and likely the whole year I've owned the truck. I'll replace a dented part, but is it likely something else could cause the "thump" or some place specific I should look?
LibertyReloaded7.3 is offline
