trouble code p1316
hey ,new member great forum.anyway my 2001 f350 7.3L was running rough and check engine lite on code p1316 inj crct idm problem.it was interm.for a while then stayed on for good.searched the net for info and found the forum.checked the harness connector inside valve cover and found it loose.ford part#2c3z 14a163 ab locking clip took care of problem and my truck runs GREAT.great info thanks
to Powerstroke.org! Glad you could find the information you needed! Thats what we are here for! |
Good to have you, glad we could help.
Glad we helped....and more importanly.......
Most dealers dont know of the locking tabs you used...i have meant to get the part number from work but keep forgetting. THANK YOU for posting it as i will now put it in the tech files to help other members
Not to revive a very old thread..but Huge thanks to this forum. My wife got home last night with the Excursion running real rough, said the check engine light came on. First instinct was the CPS was about to go, so I swapped in the new one I had in the glove box. (It had never been replaced with 145K on it). Well no change. Got the code P1316. Pulled the driverside valve cover off (that back bolt is a PITA) and found the connector was loose (****ed to one side). Didnt get a new one (probably should soon as it was 11PM), just plugged it back together. Fired it back up and runs great again.
AGAIN. Huge Thanks to this forum. ![]() Are both sides prone to this problem? or just the driverside? Should I replace both next time? |
I am so glad I found this. I have the same problem and it sounds like this will fix it. So is there another plug on the other side (pasenger) Do I need to get new valve covers as well?
good info hope it helps me
i have the same code and i know that my harness is loose didnt think anything of it at the time. replaced the injectors on the driver side and noticed it just pushed it in and went on about my way. ill replace the part and see if it helps.
had the same code also i replaced both wiring harnesses from advanced for $ 48.00 they have a new design that clips better. thanks for all the advice guys
I have same problem. Were is the located at. The form that tells you were the is located and how to access the harness and what not. Ty so much guys for all the help.....
both harnesses are under the valve cover they make wedges for the old harness also but i was working on a van and it takes a day to remove a valve cover on the pass. side so new harness...
