choppy acceleration - Ford Powerstroke Diesel Forum
Old 07-08-2008, 04:35 PM
Question choppy acceleration
I posted a thread about a ticking sound, like an exhaust leak, but now it is getting worse and when I accelerate, mainly low rpms, the engine runs smooth but sounds real choppy. It is definately getting worse and I'm afraid to keep driving it but I have to because it is also my work truck I use to pull a 14ft. trailer. Is this an injector issue? Do dealerships charge to pull codes? I have changed the fuel filter about 4,000 miles ago.
Old 07-08-2008, 04:37 PM
Advance Auto Parts doesent charge to pull codes. Thats who I use in a pinch!
Old 07-08-2008, 04:43 PM
Should I unplug my chip or does it matter?
Old 07-11-2008, 06:40 AM
Sounds like an injector, although if it was, your engine would not be smooth it would be shaking. Might be a GP relay.. You're gonna want to pull codes for sure and maybe to a KOER test
Old 07-11-2008, 07:34 AM
It doesn't puff any blue smoke, could it possibly be a under valve wire harness issue? What is a KOER test? Would codes pop up if no ses lights are on?
Old 07-11-2008, 07:38 AM
It could be a UVCH issue, but that should set codes as well, at least mine did. a KOER is a Key on Engine Running test on the scanner. It checks a number of things while the truck is running and might find what is causing your problem..
And yes, you can have codes without the SES light coming on.
Old 07-11-2008, 12:26 PM
In the cab it sounds like a helicopter. No shaking no smoke. Its louder when I have my chip on rather then stock setting. Still looking for a scanner but I want to ask my cousins friend if he has one rather than bending over for a dealership scan.
Old 07-11-2008, 12:34 PM
International Threat
Try to get a video of the sound and get a REAL scanner on it...
Choppy leads me to believe ICP, Fuel and Trans... but we need much more to really help.
Old 07-14-2008, 02:08 PM
got my truck scanned today, no trouble codes, just P0476 and P0605. He said its prolly an exhaust leak like I thought but been driving it for a week and a half and can't see anywhere it is leaking. Did a buzz test and nothing came back.
Old 11-17-2008, 02:59 PM
so I replaced hpop, ipr, and icp. The sound is like when you stick a playing card in a fan and it hits the blades. ? I also have a slight vibration on the floor. The truck doesn't seem to blow black smoke like it used to when I floor it. Any other possibilities? I took it to a shop and they said it had good oil and fuel pressure. No codes.
