01 7.3 doses not want to wake up - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-09-2013, 05:22 AM Thread Starter
I have a 01 7.3 185,000 mi lately it has been sputtering and missing after sitting over night unless I let it sit and idle in the driveway for 5min. this morning it cut off on me twice and took a long start attempt to get going. If I sit with my chip on high idle it will smooth out and be fine and will be fine for the rest of the day. Any ideas on what I should look at. It has anew fuel filter so we can take that out
Thanks
01moneypit is offline
post #2 of 9 Old 10-11-2013, 10:07 AM
CSIPSD's Avatar
Glow plugs... OR more likely a Glow Plug Relay.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 9 Old 10-11-2013, 10:32 AM Thread Starter
Thanks I can fix that
post #4 of 9 Old 10-13-2013, 11:14 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
you getting lots of white smoke out ofthe tail pipe?
also another indication your glow plug system has failed.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #5 of 9 Old 10-15-2013, 04:53 AM Thread Starter
Not on start up it only acts up after I start down the road other than that it starts fine if it was gps would it not have a hard time starting?
post #6 of 9 Old 10-15-2013, 07:59 PM
Quoted: 270 Post(s)
bad glow plus or glow plug relay make the truck hard to start in the cold. with white smoke out of the tail pipe.
how long has it been since you changed the oil, or is your oil possibly low?
post #7 of 9 Old 10-16-2013, 03:02 AM
schlutzer's Avatar
Quoted: 18 Post(s)
So the truck starts up okay, then starts running like crap?
You might be looking at damaged injectors then on the severe side, they generally show up with more symptoms when cold, smoothing out when warm.
Or like blue99 said, the level and condition of your oil makes all the difference, I chased a constant miss and rough start for about a month before I realized I had fill up short by about 1litre the previous oil change.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #8 of 9 Old 10-16-2013, 03:10 AM
Powerstroke Man 6.4's Avatar
^ WHS been chases a misfire and rough idle when warm for the pass month and turned out to be 3 quarts low on oil LOL. It also could be damaged injectors because of the oil thining out when the oil gets warm. Causing the rough idle and running.
2012 Ford F-350 SRW 3.55 LS Lariat Blk Crew Cab Spartan 200 Hp Tune Warhammered 5 In MBRP EX AFe S 2 CAI
2008 Ford F-350 White XLT Crew Cab DRW
MPRP 4 IN Downpipe Back DPF Cat Delete Stright Pipe Spartan 300 LL Tune AFe ST 2 CAI MBRP 3 IN Intercooler Pipe. 4.30 LS
Late 1999 Ford F-250 XLT X-tra Cab White 7.3 SRW 6637 MBRP 4 IN Turbo Back Exhaust No Muffler DP-Tuner And PHP Hydra T-500 Swamps 160/100% Inj Airdog Swamps HVHF IDM GTP38R W WW2 305,000 MI 3.73 Non LS
Powerstroke Man 6.4 is offline
post #9 of 9 Old 10-19-2013, 05:35 AM Thread Starter
It really runs ok as long as I let I warm up I just can't get in crank it and take off after it's been sitting for more that 4 hrs or so the oil could be due so that magi be it. I have noticed it is running rich as well. I did change the CPs witha borg warner and that has helped the idle and No more stalling at stop lights.
