Fuel pump sending unit - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-06-2013, 02:55 PM Thread Starter
mr.limited04's Avatar
I have a 2000 f250 and when it gets to a 1/4 tank of disel it runs out. Could this be my sending unit or some in my tank? If its the sending unit were can I find one besides dealer they are 500 there.
mr.limited04 is offline
post #2 of 3 Old 10-06-2013, 03:35 PM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
What happens is this, the pick-up and "mixer" assembly is prone to cracking and allows the pump to suck air at around 1/4 tank. There's probably nothing wrong with the sender, you may actually have a quarter tank remaining when it "runs out".
So, what you want to do is to run it low, use battery power (jumper pack or something) to run the fuel pump with the drain valve open (on the fuel bowl) to empty the rest into cans, and get all the fuel you can from the tank. Then drop the tank, pull the sender/mixer/pick-up unit and inspect it. Then, really weather it's cracked or not, do what's called the Hutch Mod because the whole system sucks anyway!
Welcome to guzzle's In-tank Hutch Mod Web Page
NoRalPh is offline
post #3 of 3 Old 10-06-2013, 03:58 PM Thread Starter
Ok thanks alot
