Battery Light on but good voltage - Ford Powerstroke Diesel Forum
Old 07-02-2008, 03:10 PM
Driving on the highway today I looked down and out of the blue the Battery indicator light was on but the voltage meter was still reading normal. Shut the truck on and off stopping certain places, but the light wouldnt go out. I havent tested the voltage of the batteries or the alternator yet but wanted to see if there was any pointers or ideas on what might be the issue.
Old 07-02-2008, 03:18 PM
duct tape & zip ties
Need to do the tests on the alternator and batteries. It didn't come on for no reason.
Old 07-02-2008, 09:33 PM
check the wire on the back of the alternator make sure the connection is clean and tight ... I had that issue in my 550 and it was the wire on the alternator not getting a good contact
Old 07-17-2008, 02:15 PM
my guess is alternator
I had the same problem recently. It turned out to be a bad alternator. The alternator checked fine with the portable check machine, took it off and it checked good at the alternator shop, still had red light on. Decided to replace it anyway, and guess what, red light went off.
Old 07-17-2008, 05:43 PM
yeah i just replaced it because the autoparts machine said the regultor wasnt getting any voltage.
Old 07-17-2008, 05:54 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
had the same problem on a 97 p.s. it was a broken wire on alternator plug
Old 07-17-2008, 06:29 PM
Shade tree mechanic
+1 for me too
Old 07-20-2008, 04:45 PM
LBT LBT is offline
Just had the same problem, symptoms, and indications last week. Replaced the alternator and all is well. It was a very easy fix.
Old 07-20-2008, 04:52 PM
yep its usually the alt, and ya prob the easiest thing to change on the truck
Old 07-20-2008, 05:12 PM
Yeah I'm thinking alternator too. It took me about 2 minutes to remove it. Get it tested for free at an Advance Auto or somethin.
