ODD thing on WOT with hot tune... - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-04-2013, 09:40 PM Thread Starter
I notice today on my 120hp tune from PHP during a few WOT runs it would go then stall for just a second, go then stall again for a second. I don't know if stall is the correct description, but it spools and rpms rise fast, but it slows for a second then goes again then slows again for a second then revs higher. It only does this on my 120hp tune. Is this a fueling issue or something? Any help would be appreciated.
My truck is an 02 ccsb, stock turbo, 4" dp and exhaust, intake, php hydra
Thanks
Dave
lexinator02 is offline
post #2 of 13 Old 10-05-2013, 10:21 AM
Vannnce's Avatar
Quoted: 13 Post(s)
do you have gauges? If so how much boost does it do this at? sounds like its de fueling when over boosting. Do you get a check engine light turning on for a few moments during this?
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 13 Old 10-05-2013, 10:31 AM
KillNThrill24's Avatar
If it does it only on the 120 tune I would have to imagine your 120 tune is no good. Which doesn't make me feel good about knowing I have a Hydra in the mail...
KillNThrill24 is offline
post #4 of 13 Old 10-05-2013, 10:36 AM
timmyboy76's Avatar
could be fuel related, hpop not keeping up...120race, i'd think, would demand alot.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 13 Old 10-05-2013, 12:24 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
most people are still running the original Fuel pressure relief. the thing wears out in 100k miles and who knows what fuel pressure is unless you have a fp gauge. the brass poppet gets worn out, and the orings are shot.
not to mention some folks (my dad) never change their fuel filter
but your hpop could be having trouble keeping up as well.
php tunes are programmed to not defuel, they still set the light for overboost though.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 13 Old 10-05-2013, 12:58 PM
Mearntain's Avatar
This is not a hydra problem, this is an issue with the OP's truck having something that can not keep up with the demands of the tune. You should have no worries and be happy with your purchase. My 120 race tune works perfect, even the 140.
2001 F250 7.3 4x4 - Reg Cab, Long Bed
AFE Stage II intake, 4" turbo back exhaust, 4 gauge Isspro pillar, PHP Hydra Chip, 35" BFG All Terrains with Fox 2.0 Shox all around, 4" lift
PSN - Rowe
Mearntain is offline
post #7 of 13 Old 10-05-2013, 01:58 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Sorry...but I gotta say this...ONE Post about the 120 race tune on the hydra chip and you feel badly about it?
More than likely its related to the truck...not the tune
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #8 of 13 Old 10-05-2013, 06:04 PM Thread Starter
I do have gauges but have not checked the fuel pressure yet. Fresh fuel filter. I see about 24psi on that tune. It spools really fast to 20psi and then slowly builds.
Don't talk bad about the Hydra. I love it and it's a great product. I was in no way blaming them. I'm sure it could be fueling related.
I will have to get a fuel pressure gauge and see what I'm at. Where should I be PSI wise?
Thanks
Dave
post #9 of 13 Old 10-05-2013, 06:09 PM
Doesn't Even Care
Quoted: 69 Post(s)
If you have the stock spring in there, 45-55 psi
Nick
"The Mistress"
post #10 of 13 Old 10-05-2013, 06:35 PM
Mearntain's Avatar
I've got a stock spring and I maintain 62-64 psi. Just make sure you don't get below 35 psi or that's no good for your injectors.
PSN - Rowe
