7.3 Studder Problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-02-2013, 07:01 PM Thread Starter
7.3 Studder Problem
I bought a 7.3 Powerstroke and it studders while at 0-15% idle. Once boost reaches 5psi, the engine smooths out and runs strong to redline.
I have replaced:
#2 injector
#8 injector
crank position sensor
cam sensor
IPC - high pressure oil
IDM - new reman
new UVCH - both banks
new batteries
new fuel filter and cap
It still studders at low rpm and chugs bad at 1500rpm - 2000rpm
It also idles rough.
I've brought the truck to two different powerstroke shops and neither shop has found the issue. The only good they have done is test the fuel pump and said that it still runs strong.
Any help would be very much appreciated.
Thanks!
gtm060584 is offline
post #2 of 3 Old 10-03-2013, 04:38 AM
Seth14's Avatar
If you have the capabilities, check your icp numbers at idle and your ipr duty cycle. Post them up here as well. Could be a number of sensors that could be bad....but those numbers could get you started.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #3 of 3 Old 10-04-2013, 01:25 AM
i had a similar problem once, turned out to be two of the injector selenoids were shorted out from a previous uvc issue. tested the ohms between the two pins at the selenoid and two were way off
yooper906 is offline
Tags
idle , studder , stutter
