What the hell is up with IH??? And my motor won't start after intake cleaning.. - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-28-2013, 03:27 PM Thread Starter
broncomitch's Avatar
Exclamation What the hell is up with IH??? And my motor won't start after intake cleaning..
So I'm screwed.
I noticed that one of my IC boots was about to come off I noticed that's where all the oil is coming from (I think ) so I pulled the intake and cleaned the boots and intake
Wile I was in the intake I cut the AIH and ditched the hot wire for it but put the ground back on to keep it out of the way.
We'll I cleaned everything up and used hair spray on the boots and hooked everything back up but the truck won't run!!!!
I'm looking around and found my fuel leak and it's the fuel line on eh side, I tried to tighten it up but made it worse.
Pull the line off and the sleeve is just destroyed.
So I call IH and they said cus of the 6.0 scandal ford and IH had he can't look up parts for my 7.3
Said he has no way to even look up new sleeves unless I have a part number!
So I called everywhere and no luck.
Ether closed or can't find the parts...napa is my only hope tomorrow
Dose anyone have the part number for those fuel line sleeves????
Or do I half to order a kit and miss work all those days?
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #2 of 23 Old 09-28-2013, 03:45 PM Thread Starter
The leak at first was a very small drip... Would that cause the motor not to fire?
Also wile I was cranking the motor I saw white smoke come out the motor compartment!
It didn't have a electrical smell, so I'm not sure what it was..
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #3 of 23 Old 09-28-2013, 04:02 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I have a feeling you cut some bad wires or shorted something.
Will it crank and not start, or not crank at all?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 23 Old 09-28-2013, 04:09 PM Thread Starter
Crank, no start.
I was looking around and all I can find was the fuel heater plug on he back of the fuel filter housing wasn't pushed all the way in...
Other then that nothing that I can see.
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #5 of 23 Old 09-28-2013, 04:14 PM Thread Starter
Not sure if it matters but I didn't disconnect the the battery.
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #6 of 23 Old 09-28-2013, 04:17 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Key on, engine off, does the WTS light light up?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 23 Old 09-28-2013, 04:27 PM Thread Starter
Yes, and turns off
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #8 of 23 Old 09-28-2013, 04:36 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Hmmm.
Does oil pressure come up after cranking a while? If you empty the fuel bowl, does it refill after leaving the key on engine off?
I would ohm all your fuses just for the heck of it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 23 Old 09-28-2013, 04:47 PM Thread Starter
All the fuses are good.
Apart from maxi 16
(Trailer charge)
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #10 of 23 Old 09-28-2013, 04:49 PM Thread Starter
Didn't notice the oil, but yes the housing filled up with fuel again.
Have not tried to start it sense that fuel line is off..
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
