'02 F-350 Intermittent No Start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-12-2013, 06:51 AM Thread Starter
I have a customer of mines 2002 Ford F-350 7.3L bone stock, they bought new never had any trouble with it. It has a intermittent no start issues, that the truck just cranks and wont start. No Codes, ICP Pressure on no-start 1000+ psi, cranking RPMS are present. We Have replaced The ICP, IPR, Cam sensor, and done a Reflash to the latest software. Still trouble about 1 and 20 times of starts it will not start. Next time starts fine shut it off, starts fine shut it off, then no start and crank crank crank, turn key off go right back and it will start. Sometimes the no start might be right out of the hole, their is a trend to it very intermittent and like I said no codes passes all test KOEO and KEOR tests. When the truck starts it runs beautiful no problems, if you shut it off it may not restart. Oh the Truck has low miles to 106,000. Any help would be great.
Briansdiesel05 is offline
post #2 of 4 Old 09-12-2013, 10:06 AM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Yea but, those reading are when it's not having the problem - right? Have you had the scanner on it when it doesn't start?
I gotta think electrical with those symptoms. Is the IPR plug wires in good shape? Maybe unplug the ICP when it's doing it?Do you get a WTS when it does this? Could there be water in the IDM?
Hopefully, it gets worse .
NoRalPh is offline
post #3 of 4 Old 09-12-2013, 10:34 AM Thread Starter
The results of ICP of 1000+ psi are when it doesn't start and the same for the cranking RPM's, I have been able to monitor them while the no start happens. Its a strange one sometimes its fine for a while then it will screw up, makes me look like a idiot though.
post #4 of 4 Old 09-12-2013, 11:08 AM
Quoted: 143 Post(s)
Hehehe - Been there, done that
So,,, again, electrical,,,, and the PCM & sensors are good, I'd be thinkin' IDM as a likely culprit (take it out and shake it for water maybe).
NoRalPh is offline
