Truck will start up and run... no tach, no oil pressure gauge, no temp gauge
My truck will run, but the throttle won't work and none of the guages work, but the lights on the instrument cluster will work. What should I look @?? I checked the fuses and they look ok.... did this as I was stopped then when I hit the pedal.... no guages and no throttle....
![]() ![]() You checked all the fuses? |
Im not sure about if this is right but maybe the acc wire in the ignition harness doesnt have power does that radio work. kind of a shot in the dark.
computer is what id say, do you have a wait to start light?
I had a blown 10amp fuse..... put that in and good to go.. did the same thing the next day... and no problems since.
I have the same issue on occasion and its because one of my battery connectors was shot...rought start too because of it. I'll buy a new terminal sooner or later....lol
Seems I solved it, my o/d wire had become bare shorting out and blowing the fuse... got a new shifter handle works great now....
