HPOP LEAK - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-31-2013, 09:22 PM Thread Starter
Not another PowerPoint
Unrated Diesel's Avatar
HPOP LEAK
Just replaced the Reservoir gaskets top and hpop gasket and it still leaking. Found out the problem the two bolts that hold the HPOP to the lower reservoir has stripped the bolt and the seat. The two bolts go in but only spin, and never get tight. Removed everything today went to my local bolt store and purchased a standard bolt one size larger 3/8-16 x 2-1/4 grade 8 and a Irwin 3/8 Tap set. Also the fitting for the fuel bowl broke looking at buy the FPR Housing Billet aluminum Diesel Orings and line. Gonna try put this together ill keep you folks updated
UPCOUNTRYDIESEL
Had H&S wasnt that great so dont tell me there good
2012 F350 6.7L Spartan Tuner ETC.
2008.5 F350 6.4L DWR Spartan Tuner ETC..
1999.5 F250 7.3L DP Tuner... Blah Blah RACETRUCK
Unrated Diesel is offline
post #2 of 2 Old 05-10-2014, 05:35 AM
This same thing just happend to me on my OBS ...how did everything turn out?
[SIGPIC][/SIGPIC]Late 95 F250 XLT Ext. Cab Long Bed
4in Rough Country on 34s
Built E4OD w/ Triple disc TC
Swamps Stage 1 w/ Swamps ts-6
IRATE E-Fuel w/fuel lab regulated return
Swamps IDM
Adrenaline HPOP
Melling LPOP
4in pipe all the way back w/ 7in matte black tip
AFE intake with Napas "Big Dog" air filter
Banks Fast Spool comp housing
EBPV gutted
Wicked Wheel 2
GLOW SHIFT 4 gauge pillar
MM lock out hubs
limo tints all the way around
RushFORD is offline
