wont start/dead battery condition - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-31-2013, 08:19 PM Thread Starter
i have an 02 excursion with the 7.3L and was wiring my train horns in today. truck acted fine. now once i was finished with the wiring and tried to crank it i get nothing. then i put a battery charger on thinking my stereo killed the battery and it just clicks. cant even roll up the window. i unwired everything i hooked up and it still doing the same thing. batterys load tested fine and have 12.3 volts. could it be a fuse? its acting like a bad ground though.
greasemykey is offline
post #2 of 5 Old 08-31-2013, 09:23 PM Thread Starter
ok so it was a bad ground as i thought. cleaned and she fired right up. now my abs light is on and i have no power to the brake controller.
post #3 of 5 Old 09-05-2013, 09:00 AM
Powerstroke Junkie
NCHornet's Avatar
abs light being on indicates that you should have a stored code. Have it read by a scanner with the correct Ford Bundle since these trucks aren't OBDII compliant. A couple things to check at home would be all fuses and the ABS lines where they attach to the rear of each hub.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #4 of 5 Old 09-05-2013, 11:05 AM Thread Starter
the abs light turned itself off. i know a few weeks ago when i destroyed a front wheel bearing i killed the abs sensor but it went away when i replaced the hub. could it have been displaying that code again because i never cleared it? still not sure why it was on. still no power to the brake controller. and i cant find anywhere on the internet where it gets power from.
post #5 of 5 Old 09-06-2013, 01:37 PM
Powerstroke Junkie
NCHornet's Avatar
I don't have the schematic in front of me, check all your fuses. No it shouldn't of been displaying a old code that had already been corrected.
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
