03 192k cut off at idle and cuts out while driving - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-26-2013, 06:07 PM Thread Starter
03silverstroke's Avatar
Hey guys I have a 03 with 192k for the past few months it has been cutting out from time to time while driving, seems like its usualy when I am just holding the throttle steady, some times twice a day and then it might be a week before it does it again. Also it has cut off maybe 3 times while in park at idle.
Thanks for the help
03silverstroke is offline
post #2 of 8 Old 08-26-2013, 06:42 PM
Seth14's Avatar
Bad cps maybe.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #3 of 8 Old 08-26-2013, 06:46 PM
miked.'s Avatar
ipr nut, maybe
miked. is offline
post #4 of 8 Old 08-26-2013, 06:50 PM Thread Starter
I replaced CPS about 6 years ago before the recall, had another person say that today also. Guess I should take to the dealership and have them do that recall and the cruise control also. Is there a problem with having tuner or chip on truck for recalled parts?
post #5 of 8 Old 08-26-2013, 06:57 PM
Seth14's Avatar
X2 on the ipr. My truck was doing the same thing and for some reason I was thinking it was the cps but it wasn't. It was my ipr that was bad. I fixed a lot of things on my truck when I did my build. My truck would occasionally die at a stop light or suddenly miss at cruising speed. Plug your truck in and see what your ipr percentage is at an idle. Should be about 10-12%. When mine was bad it was stuck at 29% idling.
Seth14 is offline
post #6 of 8 Old 08-26-2013, 07:20 PM Thread Starter
Another thought I just had was last week droped the tank and cleaned the filters in tank, when pulling it in the shop had people ask why does it smell so strong. Yesterday my wife and I stopped at the store and when we came out it was not running, It started right back up but my wife was still behind the truck and said it was burning her eyes when started
post #7 of 8 Old 08-27-2013, 08:00 AM Thread Starter
ICP possible? I took the connector apart and it was full of oil and you can see where oil has been shooting out of the connector.
I know that no matter what the ICP needs to be changed, but do you think this could have that much effect on the IPR getting false info
post #8 of 8 Old 08-27-2013, 11:35 AM
Seth14's Avatar
It's possible. If the ecm detects a problem.....ie bad icp.....it will go into a kind of "limp" mode.. a factory default setting in the ecm.
Seth14 is offline
