Dead spot in pedal - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-23-2013, 04:25 AM Thread Starter
bamfdavid's Avatar
Dead spot in pedal
Hey guys I'm experiencing a "dead" spot in my acceleration pedal. But it only Happens when the truck is in o/d with the converter locked. The first 1/4 of pedal feels normal. After that it dies. Could it be my pedal or what? Oh and I doesnt do it all the time just every now and then. Thanks for any help guys.
99.5 super duty, TS chip cranking up 140. 4 inch straight pipe, cold air intake, x wheel, zoo dad, mildly built trans. Running 35s- sold
04 HD F-350 Studded and deleted, SCT with Gearhead SRL++, Edge CTS, KC Billet wheel, FICM tunes
bamfdavid is offline
post #2 of 7 Old 08-23-2013, 06:08 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Is this dead spot like it just doesn't accelerate more or the truck acts like you let off?
There is a sensor on the pedal that when it goes bad it'll cause the PCM to see 0% throttle pedal.
Mine scared me, it would let me take off, then the engine would drop to idle. Took that happening 1 time while crossing an intersection to get it fixed. Apparently some people have luck cleaning it. I just replaced it with a junkyard part.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 7 Old 08-23-2013, 06:14 AM Thread Starter
bamfdavid's Avatar
Its like it works full pedal while the tc isn't locked but once it locks in o/d its like the truck doesn't accelerate it doesn't die like idle but still has like 25% power. I have a spare pedal at home I'm gonna have to try before I get stuck in an intersection.
post #4 of 7 Old 08-24-2013, 03:23 AM Thread Starter
bamfdavid's Avatar
Morning bump
post #5 of 7 Old 09-17-2013, 11:00 AM
Carolina444's Avatar
Had the same problem.. Replaced the pedal assembly with a new ford unit and fixed dead spot and more power
Early 99 f250 cclb,244k, ccv, Tymar intake, 4" diamond eye, 5" tip, 140v IDM, php hydra, isspro's, riffraff boots & billet wheel, ebpv delete w/ high flow outlet.
P.I.S injectors coming soon
Carolina444 is offline
post #6 of 7 Old 10-27-2013, 06:25 PM
diesel_19's Avatar
I no this is an older post but mine is doin this also just when i pit my chip in the 140 spot did u fix ur prob and wat fixed it?
E99 f350 cclb 4x4 6speed
4in tb 6in tip
Ts chip
Ccv mod
Diy intake
Epbv delete
diesel_19 is offline
post #7 of 7 Old 10-28-2013, 05:32 AM
Not sure why it's doing it only in the 140 tune but mine was cutting in&out couple times a day.. Just replaced it with a new ford unit and haven't had any issues
