Got a 2002 f250 7.3,on the way to west va. I stopped at a toll booth.When I pressed the pedal to go the motor died,started right back up but hesitated when I tried to drive off.Has gotten way worse but doesn't do it in neutral or reverse.Any help would be appreciated.
First, check the oil level, since the injectors are actuated by oil pressure and need enough clean oil to make things happen. Second, verify the fuel filter is clean, there are no obstructions int the fuel line and the check spring is in one piece, functioning freely and properly. Third, begin fault diagnosis with the fuel injection control module (FICM) and the high pressure oil pump (HPOP). Sounds like the problem occurs under load and may also be related to the drive-by-wire input to the powertrain control module (PCM). Good luck.
***FIXED***The nut and sleeve had backed off the icp.Evertime I pressed the gas it would slide back and shut down the injectors.Started digging around in there and saw them sitting in the valley.
No dought,Free is good! "CORRECTION"(It was the ipr not the icp.)
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
