Ball joints and shady shop - Ford Powerstroke Diesel Forum
post #1 of 27 Old 08-17-2013, 10:41 AM Thread Starter
USMC2001PSD7.3's Avatar
Quoted: 13 Post(s)
Garage
So I have my truck dropped off to get new front rotors and pads and an alignment done and to check the ball joints. The shop tells me that one needs to be replaced and one of the axle seals is leaking. I told them to replace all four ball joints and the inner and outer axle seals.
This morning they call and tell me they cant do the ball joints because there is a bolt in the differential broken off and they cant move the axle to get the old ball joints out. They said it may be better to get a new differential housing.
Now im no rocket scientist but that sounds like they're trying to pull a fast one on me. Why would you need to get in the differential to do either of these jobs? Maybe someone knowledgeable can enlighten me. Two of my friends already called bs on this too.
USMC2001PSD7.3 is offline
post #2 of 27 Old 08-17-2013, 11:07 AM Thread Starter
Quoted: 13 Post(s)
Garage
http://www.superdutypsd.com/ball_joint_article.php
I used this step by step and see nothing about getting inside the differential for either procedure
post #3 of 27 Old 08-17-2013, 11:12 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Yea, you're right,,, the axle just pulls out (can take some force sometimes) and there is No Clip or Bolt holding them in. I think they're over their heads here, you should go get your truck out of their hands
NoRalPh is offline
post #4 of 27 Old 08-17-2013, 11:23 AM
ThomasvillePavers's Avatar
Straight from Mitchell's website there are only 2 steps listed:
1. Remove manual locking hub
2. Using a punch, drive axle shaft main seal from steering knuckle. Remove axle shaft and main seal
For the locking hub:
1. Remove disc brake caliper and bracket
2. Remove hub lock retaining clip, and axle shaft snap ring
3. Remove the 4 locking nuts and the locking hub
4. Remove disc brake shield and ABS sensor if eqiupped
I would also agree the do not know what they are looking at here...
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #5 of 27 Old 08-17-2013, 11:36 AM
Quoted: 780 Post(s)
Have your truck towed to a different shop. They obviously have never done a SD before. Don't let them use you as the guinea pig on your dollar.
Corey@CNCFAB is offline
post #6 of 27 Old 08-17-2013, 11:36 AM Thread Starter
Quoted: 13 Post(s)
Garage
Thanks guys. I dont know a lot about drivetrains but i know when im being lied too. Looks like a pow wow is in order this afternoon
post #7 of 27 Old 08-17-2013, 11:38 AM Thread Starter
Quoted: 13 Post(s)
Garage
O and it doesnt need to be towed thank god. I just wanted it done while they did brakes and alignment
post #8 of 27 Old 08-17-2013, 01:11 PM Thread Starter
Quoted: 13 Post(s)
Garage
Ok so they are saying its the lock bolt that allows the axle to come completely outBall joints and shady shop-imageuploadedbyag-free1376773741.948901.jpg
P/n 24 should allow the axle to completely come loose allowing the proper play to get the ball joints out
post #9 of 27 Old 08-17-2013, 01:21 PM Thread Starter
Quoted: 13 Post(s)
Garage
I went to the shop and had them show me exactly what bolt and everything caused the issue. They were very accommodating and explained everything. Didnt try to screw me over for charges. Not charging me for fluids or the 5.5 hrs of labor and the manager handled it personally. I will still be taking it to a family shop to do get the lock bolt off thats broken
post #10 of 27 Old 08-17-2013, 01:30 PM
Quoted: 157 Post(s)
As I look at your diagram, I would say that 24 locks 6 (the cross shaft that the spider gears turn on) and NOT the axle from sliding out....
Maybe I'm not seeing what they're seeing
NoRalPh is offline
