HIDs with PHP tuner - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-05-2013, 09:58 PM Thread Starter
Lambo3244's Avatar
Quoted: 4 Post(s)
HIDs with PHP tuner
Kind of a strange one fellas.
Bought a PHP Hydra and absolutely love it. One of the best things I bought for the rig. HOWEVER, I have 35w HID's in Recon projector headlights and sometimes when I turn my headlights on the ABS light will kick on and sometimes shut the truck off. Has anyone heard of this? Before I installed the Hydra chip I didn't have this issue. Not blaming PHP at all but just curious as what I need to do to fix it. Apparently some drivers I talked to had DP tuners and they too had an issue with the HID abruptly shutting off the truck. I really dont want to be rolling down the road and turn those on and have the truck shut off..... Thanks for any input guys.
01
7.3L Powerstroke
PHP Hydra Chip
G2 Brute Diff Covers
4'' Straight Pipe
Rigid Industries LEDs
AFE Stage II Intake
AMP Power Steps
BD Comp. Wheel
Fox 2.0 Factory Series Reservoir Shocks
Fox Dual Steering Stabilizer
Katzkin Leather
Lambo3244 is offline
post #2 of 5 Old 08-06-2013, 07:01 AM
Don't know if there's any relation, but I had a situation where my truck would shut off whenever I shut off my water injection. this started after I installed my PHP hydra.
I re-wired the relay for the water injection and it fixed the issue. I still have no idea what the issue actually was...something electrical...although I didn't change anything when I rewired the relay.
I'd check the wiring on the HIDs (maybe the relay has the wires switched and the resultant high current has only become an issue now that the php chip is there to call it an issue?).
If nothing else works, maybe try rewiring the HIDs? Could be a similar mystery gremlin as mine
2001 F-250 XLT
6637 air filter, zoodad w/ custom enclosure, 4" TB straight pipe w/ 5" tip, water injection, PHP hydra-chip, boost, EGT & trans temp gauges, Sonnax valve tricumulator kit, AIH delete, foil delete, external IC/TC water mist spray
Troponin is offline
post #3 of 5 Old 08-06-2013, 08:01 AM
Power Hungry's Avatar
This is an issue that has plagued chip manufacturers for years. Some chip designs seem to have more of an issue with interference than others, but it all seems to relate back to high current draw circuits introducing interference into the chip itself (either by linked circuits or by cable proximity) and causing the processor/logic to stall. In most cases it's a proximity issue and rerouting the cable will resolve the issue.
When we designed the Hydra Chip, we went to great lengths to test and shield for interference because of the issues we've seen with other chips. To the best of my knowledge, this is the first complaint we've had about interference with the chip and we will be taking a second look at the chip/cable design and see if there are any other areas where an improvement can be made.
If you have any further issues with interference, please contact us directly and we'll be happy to see what we can do to get the problem resolved for you.
Take care.
Friends don't let friends drive JUNK!
2001 7.3L - Stage 1's at 399 HP - Just a lonely Daily Driver
2004 6.0L - Under Construction!
2016 Focus ST - A blue bundle of fun
Power Hungry is offline
post #4 of 5 Old 08-06-2013, 10:49 AM Thread Starter
Lambo3244's Avatar
Quoted: 4 Post(s)
Troponin, appreciate the input buddy. I will talk to PHP here within the next day or two and take a look at what I need to do to fix the issue. Thanks guys!
01
7.3L Powerstroke
PHP Hydra Chip
4'' Straight Pipe
AFE Stage II Intake
AMP Power Steps
BD Comp. Wheel
Katzkin Leather
post #5 of 5 Old 08-10-2013, 12:24 PM
If the ABS light doesn't flicker and the truck doesn't shut itself off any other time EXCEPT when using the HIDs, then you have found the source of your electrical interference. Either eliminate the interference (cheap relays) or shield what is being interfered with. Funny thing is someone on another post had exact same issue with his DP Tuner & HIDs, and some idiot told him to get rid of the DP and get the PHP instead.
Kopperhed
Bixby, OK
2000 F250 2WD daily driver & tow rig
Wanderer Wagon 327WTB approx. 10k lbs
Kopperhed is offline
