p0500 and p0603 codes help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-01-2013, 07:46 AM Thread Starter
My OD off light flashes at low speeds ABS light stays on cruise control not resuming after breaking
any help greatly appreciated 1999 7.3 L 68,000 orig miles cam sensor already changed twice last recall was assured the problem was solved truck runs great..
just not sure about these codes.... Thanks in advance for the help
racer1234 is offline
post #2 of 5 Old 08-01-2013, 10:50 AM
Macon's Avatar
0500 is your speed sensor, and that does communicate with cruise, and I believe ABS as well.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 5 Old 08-04-2013, 04:16 PM Thread Starter
Thanks Macon is this an easy fix now spedo does not work until truck reaches 30 MPH....
post #4 of 5 Old 08-04-2013, 04:40 PM
Macon's Avatar
Never done it myself, nor looked into it. Do some searching on here and you will be able to find a "how to". If I recall, it's a sensor on top of your rear diff.
2002 F250 CCSB 4x4
Macon is offline
post #5 of 5 Old 08-04-2013, 06:00 PM
kclough's Avatar
I replaced the speed sensor on my f150 it was one 10mm bolt if I recall and it unplugs. On my f150 it was a 5 minute job i imagine its probably the same for super duties
kclough is offline
