Adjusting valves - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-31-2013, 03:04 PM Thread Starter
Adjusting valves
I'm rebuilding my 7.3. I put my heads on put the pushrods in and rocker arms on. I torqued the rocker arms to 20lb. As I was torquing them every exhaust valve opened some only a very small amount and some more. I'm sure the ones that opened more are on the high lobe of the cam but why would the ones on the low lobe open? They only open a small amount but I don't think they should open at all. Thanks for any help
Late 1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 135,000 miles. Late 1999 f250 ext cab.4x4 auto FF stage 1 injectors non EBPV pedestal, GTP 38R turbo, hydra with powerstruck tunes, gauges. 213000 miles.
Jdg5147 is offline
