Brakes - Ford Powerstroke Diesel Forum
Old 04-29-2008, 02:09 PM
Brakes
My brakes on my 2002 F250 are pulling real hard to the right, i noticed it a little before i went on a trip but didn't think much of it. by the time i got back from our little trip it was pulling so hard i decided to put new brakes on it, that didn't help at all. It pulls so bad to the right that i have to compensate by turning my wheel left, does any one know what is wrong with it?
Old 04-29-2008, 02:18 PM
duct tape & zip ties
Check the hubs. They maybe frozed up causing this problem. My co-worker just had this problem. Cost him 650 dollars. He replaced his hubs with the Warn hubs. I suggest you take the hubs apart and clean them and then reassemble.
Old 04-29-2008, 02:35 PM
YEAH BUDDY!
Frozen Caliper pin?
Old 04-30-2008, 06:40 AM
Feedback Score: 5 reviews
Stuck piston, new rotors?? or did you use the old ones?, check Hub's, unit bearings and ball joints.
Cary
Old 04-30-2008, 06:42 AM
Originally Posted by sevenmalards View Post
Frozen Caliper pin?
What he said. my friends were froze up and his pulled hard to one side also
Old 04-30-2008, 06:53 AM
the pins are a huge problem every pickup i have had did it until i took the caliper pins out and cleaned and re greased them then it stopped and the brakes worked fine
Old 04-30-2008, 07:26 AM
YEAH BUDDY!
Or just buy new ones, I think they are like $15/pair
Old 04-30-2008, 09:08 AM
yea thats true i always just used a soft grinder wheel like really soft and cleaned them up really good and then put grease on them
