Im looking at a 2000 f250 and the guy who is selling it says that the truck wont start unless its plugged and if it starts in the morning then it can sit for a little bit and will start right back up but if it sits for like 5 or 6 hours it needs to be plugged back up what could be causing the problem and the other thing is the speedometer wont work until the truck is going atleast 40 and he says the abs light comes on because of that so what could the problem be on that. Thanks all help is appreciated.
Call around. I reccomend switching to single ahots. But that requires tuning . Stage 1s and tuning will run you right under 2 grand. If you stock replacements. You can have them rebuilt for iv been quoted $850-1300
And are injectors hard to change or would you recommend mechanic
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
