Air Conditioner - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-20-2008, 08:25 PM Thread Starter
Air Conditioner
I have a 2001 F250 7.3. I have noticed that when I'm cruising down the highway or idling for several minutes my air conditioner stops cooling. When I accelerate it cools properly. I checked the charge and it shows the system is fully charged.
Any ideas?
woodall1 is offline
post #2 of 18 Old 04-20-2008, 08:39 PM
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
When your idling it will stop cooling, since the compressor isn't spinning fast enough to keep everything moving at "cooling speed"
But when your crusing down the highway it should.
Maybe you have excessive moisture built up and need to have a reclaim/recharge done.
I know you said it showed "system charged" but it's just reading volume, not the type of volume, or what it is.
Sounds like a quick service where they reclaim all the r134 (and all the compressor oils/condensation/moisture) and recharge it with brand new stuff is what you need.
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #3 of 18 Old 06-21-2008, 05:10 PM
dumokie's Avatar
Send a message via Yahoo to dumokie
A/C is funny. NOT funny Ha Ha..
Mine is doing same thing, did evac. and recharge.. Checked pressure switches. What source does power come from through the switches to compressor???
By switches I mean low pressure and high pressure.........
Powerstroking
dumokie is offline
post #4 of 18 Old 06-22-2008, 10:04 AM Thread Starter
I've noticed that its more random when it stops working, not just at low RPM's. I left it running and ran into a friends house and it stayed cool after 10 minutes at idle. Then I kicked at it the off ramp going onto the highway and in never would cool. Is there some type of temp. sensor than could be on the fritz?
woodall1 is offline
post #5 of 18 Old 06-23-2008, 05:52 AM
dumokie's Avatar
Same problem
Woodall your description of problem sounds exactly identical to mine. I will do some checking on why we are losing power out to compressor, I am sure it is not a pressure problem nor the high or low pressure switches as I have bypassed them both only to have same symptoms.. If you find anything please lemme know. Thanks
Powerstroking
dumokie is offline
post #6 of 18 Old 06-23-2008, 09:36 AM
Cj Ford's Avatar
check the air gap for the compressor's clutch, it may be to big and you need to remove a shim.. or the magnets could be week and not pulling the clutch to engage
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #7 of 18 Old 06-23-2008, 07:18 PM
dumokie's Avatar
No power at all.
Thanks CJ, but I am losing all voltage to the compressor as I have installed a voltmeter to clutch wires while I drive. I am going to have to trace the wiring that comes out to power up the compressor back into the vehicle. I was hoping someone had run into this before. I think there is either a thermister (thermostat) in the evap. unit or the power is applied from the ECU.. Whatever parameters satisfy the ECU to tell the a/c to kick on are maybe not being met?? I have checked the TPS and ran codes and none are set. I need to invest in a good wiring diagram for this truck.
Powerstroking
dumokie is offline
post #8 of 18 Old 06-24-2008, 09:45 AM Thread Starter
My truck is in the body shop so I won't have it for a week or so. I'll do some checking locally and see what I can come up with. Its HOT in NC and my guys and trash talking the 250 because the A/C is acting up. I almost feel sorry for them, almost...
woodall1 is offline
post #9 of 18 Old 06-24-2008, 09:47 AM
ADMIN AND TECH
SCUFFY828's Avatar
i agre , that is what i find to be 90 % the problem with a/c not cooling on these trucks , take the shim out, get the gap closer ,should fix it
ITS STOCK
SCUFFY828 is offline
post #10 of 18 Old 06-24-2008, 10:06 AM
southern7.3's Avatar
My 99 has a similar problem. There is a connector that is (if your looking from the passenger side fender) is left of the dip stick. When you turn the air on it sometimes will cool, sometimes it wont. Then if you push the connector from side to side you can here a click and it will go back to working. Any ideas. It was hot on the way back from the lake the other day so I jumped out and ducked taped the he!! out of it until it stayed on. I want it fixed though
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
