will start and idle, but no throttle response when pedal depressed??? - Ford Powerstroke Diesel Forum
Old 04-17-2008, 11:45 AM
Post will start and idle, but no throttle response when pedal depressed???
2002 F250 7.3L
THE TRUCK STARTS FINE, IDLES FINE BUT THE TACH AND ALL OTHER GAUGES NOT WORKING. ALSO WHEN I PRESS THE PEDAL, NO RESPONSE AT ALL- NO INCREASE IN RPMS, NO SOUND, AND MOST IMPORTANT NO MOTION. WHAT'S WRONG WITH MY TRUCK??????????
Old 04-17-2008, 04:49 PM
Try checking all of your fuses.
Old 04-19-2008, 11:11 PM
its probably a ground connection under the hood on the wiring harness sounds stupid but my did that, and there is a ground under the plastic pannel on the passenger side,
Old 04-20-2008, 02:56 AM
yeah sounds electrical, follow the wiring harness. Bad connection or ground like 87 powerstroke said.
Old 04-25-2008, 03:49 AM
This happened to me last night....a pop, then; gauges dead, and good idle...no acceleration? I let it idle back out of road and began looking in manual...there was an * beside #45 (ignition) the * was drawn there in blue ink? checked it...it was blown...replaced and it's fine! Now I wonder what caused it?
any ideas?
cale
Old 04-25-2008, 05:55 PM
Illiana Chapter Director
Originally Posted by russmet24 View Post
2002 F250 7.3L
Sounds to me like the sensor on the throttle is bad. Check your fuses and if they are all okay, probably going to have to replace the throttle pedal assembly.
Old 04-25-2008, 06:01 PM
PMR = JUNK
Check the fuse for the gauge panel and the alternate PCM or whatever. I've got a problem with mine, it keeps blowing that fuse, when that fuse goes it does the exact same thing you are describing. Im about to start a thread about my problem.
Old 04-25-2008, 06:58 PM
Lets see....wrong....wrong....and wrong..... guess agian!!!....
replace your shift lever or at least tape up the wires for the OD button that are frayed that come out of the shift lever and rub through the insilation right next to the hazard light button under the steering column cover
Old 04-25-2008, 08:01 PM
When I swapped a PSD into a formerly 460 powered truck it did exactly this, The problem was a broken wire between the pedal and the engine harness, theres only a few wires, checkem out.
Old 04-25-2008, 08:09 PM
just recently i was having that same problem, would idle but no throttle response. ended up being my IDM went dying on me. have your computer scanned.
