7.3l Oil Leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-17-2013, 08:45 AM Thread Starter
7.3l Oil Leak
Hey all
Here is my situation.
Threw pushrod 5 exhaust. Replaced it and a week later the number 5 intake bent. I ended up replacing both now in number 5 and it has been 3plus weeks and the truck is running great.
I do not have a loss of power and it is driving like it use to. But I am now leaking quite a lot of oil from the passenger side exhaust manifold.
I have the AE tool and the CCT always errors 8 (cps) and either 2 or 5 but sometimes none just 8.
I am thinking of replacing the injector orings. Just looking for any other advice before I do so.
Thanks
cflocation is offline
post #2 of 4 Old 07-17-2013, 10:21 AM
timmyboy76's Avatar
you'll want to remove the manifold and have it decked. With bad orings, you'll see smoke at tailpipe and/or i beleive oil in fuel/bowl as well.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 07-17-2013, 10:26 AM Thread Starter
I have no oil in the fuel bowl. Thanks for the idea.
post #4 of 4 Old 07-17-2013, 05:10 PM
I wonder if the valve stem seal got messed up.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
