Fuel Issues-not getting any - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-16-2013, 05:55 AM Thread Starter
ricochetbuell's Avatar
Got the kids loaded up and was waiting for the wife to leave so I could get out of the driveway when the injector noise changed pitched. Took me a minute to realize it sounded just like the time I ran it out of fuel before doing the hutch and harpoon. Move the kids over to the TDI and go to work. When I got home I I noticed that the fuel pressure was only 28psi post filter. The fuel pump is humming so I drain the fuel from the Baldwin then check the fuel bowl. When I opened the drain valve the fuel didn't just trickle out like normal, it came out under pressure and blew all over the front axle and front of the motor. I thought that was weird but kept going. Couldn't get any fuel to either the Baldwin or the bowl so after thinking about it I realized that I only had about about 1/4 tank of fuel so I thought maybe the pick up broke again. Drop the tank it's still on and was submerged. So I take the fuel line and stick it in the tank to see if I can get any suction. Several key cycles and nothing anywhere. I don't know if it would suck on your finger but it doesn't. Anyone have any input? Tonight I am going to check the fuel pressure regulator and blow backwards on the lines just to make sure there is no obstruction. If that doesnt turn up anything i am going to fill the bowl and balwdin up and see if i can at least get the 28psi back on the gauge. I still think its odd the way the fuel blew out of the bowl like that. If the rail pump is humming shouldn't it be working? I have read that those rarely fail and would rather not spend the money on a guess. The fuel pressure has always been about 60psi post filter since I put the gauges in. Again any thoughts would be appreciated.
2001 F250 Crew Cab Short Box, 4" Pro Comp Suspension Lift, Banks 4" TB Exhaust with Banks Power Elbow, DIY Intake, Banks Big Head, Upgraded Lights, Monotube Adjustable Shocks, Guages, Toyo M/Ts , CCV Mod, A/C Mod, Foil Delete, AIH Delete, Zoodad, Dinger Delete, Hutched and Harpooned, ISSPRO gauges, PHP Phoenix
ricochetbuell is offline
post #2 of 7 Old 07-16-2013, 06:27 AM
timmyboy76's Avatar
Originally Posted by ricochetbuell View Post
I have read that those rarely fail and would rather not spend the money on a guess. .
Its electrical, and moves fluid. Eventually, it'll show its age.
New Premium High Performance Fuel Pump Ford Pickup Van 7 3L Diesel E2236 | eBay
Got 1, ready for the "when". Think'n of getting another ,so when the 1st goes, i'm not out a truck, til the replacement comes.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 7 Old 07-16-2013, 06:37 AM Thread Starter
Wow that's a hundred bucks cheaper then anywhere else. Might just need to replace it for the piece of mind at that price.
post #4 of 7 Old 07-16-2013, 06:44 AM
timmyboy76's Avatar
yup...and a bunch of us, are rock'n them, to move wvo...
post #5 of 7 Old 07-16-2013, 07:28 PM Thread Starter
Ordered ordered one today after lunch. Should be here Friday or Saturday. Fi is he'd siphoning the fuel out of the tank tonight so I can reinstall tomorrow night and maybe remove the old pump if everything goes well. Thanks for the link timmyboy!
post #6 of 7 Old 07-16-2013, 08:27 PM
timmyboy76's Avatar
thats why were here, bud... Just pass'n on, what i've learned.
With fuel out of the tank, nows a good time for the HUTCH mod...Welcome to guzzle's In-tank Hutch Mod Web Page
post #7 of 7 Old 07-17-2013, 03:16 AM Thread Starter
Already done!
