Fuel Leak
OK so I may have found part of the cause of piss poor 9-11 mpg. I am leaking fuel. There is puddles of fuel on top of the engine just behind the filter housing and most of the fittings in that are are saturated with diesel. Ill post some pics. ALso you can see where the tank was punctured and patched. Ill post pics of it as well. Anybody have any ideas were this is all coming from?
i would say it's the seperator valve o-rings. I just replaced mine a new replacement was 55.00 at the ford dealer. here's the link Separator Valve Rebuild
Ya I saw that and Im gonna try that. I know thats not the whole issue but it will help to fix it.
Also you could check if the fuel lines that come off the filter housing and run to the back of the heads, i found that to be leaking where a metal clamp rubbed a hole in the fuel line.
