Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems
  #11 (permalink)
Old 04-13-2008, 08:11 AM
Jonathan734 Jonathan734 is offline
I will look at it Diesel Monkey, but it ran perfect for a while after the two new injectors, I am guessing I need to get another buzz test. Such is life I suppose. Does anyone know anybody around central IN with Auto Enginuity. I hate going to do the dealer.
  #12 (permalink)
Old 04-14-2008, 11:02 AM
Well I played with the uvc harnesses alittle and got them to connect better. So I guess I just didn't have them pushed together enough to make a good connection. Thanks for the help guys.
  #13 (permalink)
Old 04-14-2008, 11:15 AM
Deputydog Deputydog is offline
Hey glad you got it figured out!! Mine have done this too. Ford has a TSB out on it and there is a $9 part to fix the UVC harness and keep it together.. I just did mine.
  #14 (permalink)
Old 04-14-2008, 05:55 PM
southmike southmike is offline
sometimes it will run bad for a bit till all the air is worked out too, so don't be surprised if you get a rogue cough etc..until after you have a decent amount of miles on it .
