Dry rotting and disconnected! - Ford Powerstroke Diesel Forum
Old 04-10-2008, 01:07 PM
Send a message via Yahoo to drstephennix
Does anybody know what these lines are in particular? I know the largest one is the main brake line and at least one of these other ones have to be a vaccuum line for the locking hubs. Help please!? Trying to figure out the top one for sure asd its dry rotting and saw it disconnected today.
Dry rotting and disconnected!-2001-truck-008.jpg   Dry rotting and disconnected!-2001-truck-009.jpg
Old 04-10-2008, 01:26 PM
Does anybody know what these lines are in particular? I know the largest one is the main brake line and at least one of these other ones have to be a vaccuum line for the locking hubs. Help please!? Trying to figure out the top one for sure as its dry rotting and saw it disconnected today.
Old 04-10-2008, 04:19 PM
Other vehicle is an F250
ing it for you. I've never had any problems with mine so I have never tried to figure them out. I do know that if your hub vaccum line is leaking your air will only blow out the defroster and not the other vents. I think I have that right. Search on it...I'm sure you will find something.
Old 04-10-2008, 04:34 PM
duct tape & zip ties
The big one is your brake line, the small black hard plastic line is your vacuum line for your hubs, the other is not a line but a wire for your abs sensor on the hub.
Old 04-10-2008, 04:38 PM
What he said
Old 04-10-2008, 05:12 PM
THAT IS FOR SURE THE VACUUM LINE,I HAVE HAD P,ROBLEMS BEFORE W/THAT.WHAT IS YOUR PROBLEM?
Old 04-10-2008, 05:18 PM
Not sure if you know, but you started your thread again. look down the list for you answer. just trying to help.
Old 04-10-2008, 05:23 PM
Desert Shield/Storm Vet
Should be a brake fluid line vacumm line and abs line.
Old 04-11-2008, 05:11 AM
i figured it would be those three, just didnt know which was which. The top line which i guess is the vaccuum line , i found disconnected yesterday. Went to look at it and it started falling apart in my hands at the ends where it connects. I havent had a problem as of yet with my 4wheel drive, but also have not tried it since i noticed this.
Old 04-11-2008, 05:21 AM
I thought the big one was the brake line. The line on top seemed to be just a small rubber tube going from one connection on the hub to where it connects there at the top on the picture. I went to the auto parts store and bought some rubber tubing and replaced it because it was just falling apart.
