high pitch turbo whistle and stalling when switching chip settings NEED HELP!! thanks - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-07-2013, 08:52 PM Thread Starter
Usmcmudslinger's Avatar
Hey guys need some assistance here maybe someone has had the same thing happen. 7.3 01 f250 is making a high pitch whistle sometimes and it also has a bully dog chip..now the other night I was driving on economic and when changing to max I noticed that when I switched to tow the truck died...no big deal put it in neutral and try to start..but it wouldnt start on tow mode so switched and it did...now today It stalled out while on max...and wouldnt start unless set back on stock mode....any ideas?
Thanks!!!
Usmcmudslinger is offline
post #2 of 4 Old 07-08-2013, 08:44 AM
timmyboy76's Avatar
ya, your chip sucks If wanting the chip / tuner...get a real one, made and "programmed" to YOUR truck....PHP, TS, BEANS, DP..
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 4 Old 07-08-2013, 09:10 AM
ThomasvillePavers's Avatar
Does the turbo whistle you mentioned happen all the time? does it sound like metal on metal or just a higher pitch to the normal turbo whine? I also agree that the chip you have is gone bad and requires replacement, could by something else going bad and the chip switch setting is just one of the symptoms though... Do you have access to any scan tools?
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #4 of 4 Old 07-21-2013, 08:47 AM Thread Starter
I will take the truck to autozone and have it scanned...I HAD to let someone drive my truck when I got discharged from the ER as I was too "high" on meds so I think that person ****ed up the chip shifter. ..and I pulled out the hoses and checked the turbo doesnt look like the wheel is touching the housing. ..however it does have in and out play
