Have an 03 7.3 that won't crank. Main starter wire broke loose at the solenoid so I crawled up under the truck and noticed the starter/solenoid in really bad shape, so I replaced it along with a new connector on the wire. Hooked everything back up and I get nothing. Turn the key on and everything comes on, go to start it and nothing...not even a click from the relay. Pulled and replaced all of the fuses/relays and still nothing. Did a test on the starter from the battery and it is getting power and will turn over. I'm thinking some sort of ignition issue, but not sure how to trouble shoot. Any help is appreciated.
Thanks,
Mike
Thanks,
Mike
