2000 7.3 stalled, not cps - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-06-2013, 09:29 PM Thread Starter
I have a 2000 f350 with the 7.3, it stalled while pulling a trailer out of town, it had no wait to start light and no tach jump. I threw in a new cps, nothing changed. I put in a believed to be good ecu out of a 2001 psd and now I have a wait to start light and still no tach jump. im a newbie to diesels and would greatly appreciate any suggestions you guys could send my way.
jed_b is offline
post #2 of 9 Old 07-06-2013, 10:14 PM
Quoted: 759 Post(s)
Check fuse #30 under steering column.
Corey@CNCFAB is offline
post #3 of 9 Old 07-07-2013, 02:54 PM Thread Starter
checked all fuses none are blown
jed_b is offline
post #4 of 9 Old 07-07-2013, 02:57 PM
Quoted: 759 Post(s)
When the WTS light comes on can you hear the fuel pump turn on?
post #5 of 9 Old 07-07-2013, 03:15 PM Thread Starter
yes and I drained the fuel bowl just to make sure it was filling up again.
jed_b is offline
post #6 of 9 Old 07-07-2013, 03:17 PM
Quoted: 759 Post(s)
Do you have diagnostic equipment. I. E. AutoEnginuity or something to do a buzz test.
post #7 of 9 Old 07-07-2013, 03:34 PM Thread Starter
no I don't. also before the truck stalled the check engine light came on two different times. both when I was accelerating. but I hooked a simple obd2 scanner up (when the old ecu was in) and it said it couldn't connect to it
jed_b is offline
post #8 of 9 Old 07-27-2013, 03:09 PM
F350oldskool's Avatar
Mine ran rough then died and wouldn't start again. It ended up being the exhaust back pressure sensor. The one that's vertical in front of the hpop res. might be it.
2001 F250 SD ZF6
4in MBRP straight
DIY intake
TS 6 pos chip
HPX
FRX
CCV mod
Boost fooler
Wicked wheel
She aint the fastest but she runs good
Jeremy- Ft. Collins, CO
[URL=http://s1251.photobucket.com/user/F350oldskool/media/image.jpg.html]
F350oldskool is offline
post #9 of 9 Old 07-27-2013, 03:53 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If your WTS light is not coming on, you have no PCM power for some reason.
4R100, 2wd
330,000 + miles
jesilvas is offline
