99 powerstroke f-350 dying on the highway??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-03-2013, 01:55 PM Thread Starter
Arrow 99 powerstroke f-350 dying on the highway???
Hello everyone, I would just like to thank everyone in advance for any advise or help they provide.
I am a noob with diesels and I just bought my first one a few weeks ago for towing purposes
The truck is a 99 f-350 with the 7.3 and manual trans. I bought the truck and it had no issues whatsoever but since I have a double car enclosed trailer I figured it would be a good idea to go ahead and have an intake, exaust and chip thrown on at my local diesel performance shop.
After I got it back from the shop I can't make it anymore than 20 miles on the highway before the egt's start dropping and eventually the truck shuts off completely. I took it back and had them update the chip, check the injectors, replace the fuel pump, replace the fpr, and still does the same exact thing and I don't want to keep wasting money throwing parts at the thing because it isn't helping. When the truck dies, if i let it sit for about 5 mins it fires up and drives just fine for a few minutes then proceeds to die again. Over a 20 mile stretch it dies anywhere between 1-5 times the exact same thing everytime. It starts as a slight hesitation but within 1-2 mins of the hesitation it dies completely with egt's around 200 degrees
To me it seems like the chip is what is messing with it because before it never had this issue. It is an edge evolution cs dash mount just so you know, and I want to see if this is a common problem for anyone else?
Again thanks in advance for any help and Ideas, my shop just has no idea whats up and I need my truck to run asap.
pettyboy69 is offline
post #2 of 5 Old 07-03-2013, 02:10 PM Thread Starter
oh also the chip says its throwing code p0340 CMP sensor circut malfuntion and p1211 injector control pressure. I had the cam sensor replaced twice by the same shop with oem ford sensor and still nothing. I talked with them again today and we are wondering if there is a glitch in the chip that messed up the oem computer in the truck?
post #3 of 5 Old 07-03-2013, 06:57 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
take the chip out and see what it does.
they may have installed it incorrectly.
p1211 is injection pressure above/below desired.
thats just from the chip calling for higher oil pressure than stock
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #4 of 5 Old 07-04-2013, 08:04 AM Thread Starter
I just talked with the shop again and when they worked on it last they completely uninstalled the chip and diagnosed the problem with it off the truck
post #5 of 5 Old 07-16-2013, 01:25 PM
Check your IPR. I was having a similar issue where my truck would just all of sudden die. At first I was able to restart right away but it eventually got worse. The coil on my IPR valve was opening up when it got hot.
Sent from AutoGuide.com App
cory32 is offline
