Ok guys, the truck has no balls...
Trouble towing...
Trouble having balls.... :doh:
Details:
1.) 2002 F350, ~165K miles
2.) just changed tranny fluid
3.) mods in Signature
4.) towing ~6.7K lb boat.
Symptoms:
1.) Loud noise, sounds like "noise", no whine, it sounds like a huge fan is blowing....hard to describe.
1.1) Loud noise is also noticeable when I put the pedal down when not towing.
2.) my Edge Juice is pulling out the tune.
3.) EGT's around 1000-1100 F (which is hotter than normal) and I can barely hold 65 mph going up hill...used to be able to hit it at 75 no problem.
4.) Turbo Surging pretty badly, I can hear it making a loud buzzing noise.
NOTE: symptoms 2,3,4 seem to only happen when towing.
I agree with your diagnosis. Sounds like you already have it figured out. If you have a trusted transmission shop take it there and have them pull codes. It will show slippage and other issues. At least you will be able to confirm that part either way.
I dont think I can get my psi up above 15psi, which is definitely low. I have tomorrow off and I will check this out before the drinking commences :woot:
"Bump" gets the thread back into the pool on the homepage so it gets more views. Just a way to keep a thread from dieing <-- how do you spell that word?!
Okay. I'm new to this. Thanks! (It's "dying"). Btw, All symptoms tell me it's a leak in the pressure system. I just hope for it to be a rubber boot that ruptured. Quick and easy fix.
Your going to loose some pressure when doing the test through your intake due to one or more slightly open intake/exhaust valves. But not much. The more details you gave and thinking about it more is sounds like your EBPV is going closed causing turbo noise/ loss of power. It is tied in with the EOT sensor. When it's cold it tells the EBPV to close until the oil gets warmed up. Maybe the EOTsensor is wiggin out. AE software will help you diagnose this much better.
So there is some soot buildup where the exhaust manifold hits the up pipe, right beneath the junction on both sides. Definitely an area where some pressure can be lost, are there gaskets in there that could have gone bad?
Truck will not exceed 15psi at WOT, EGT's hit 1200 F.
All boots look good.
Found soot beneath the donuts on both up pipes, right beneath the y pipe.
could that leak at the up pipes cause this much of a problem?
Maybe it is also combined with a partially stuck EBPV?
Truck doesnt seem to make the loud noise I was talking about (this is not the EBPV dumping, i can hold some boost) until its warmed up, ie, getting off the freeway I notice it.
Your hitting somewhat higher egts because higher rpm your injectors are dumping more fuel, but since your not getting boost/air flow its not pushing the exhaust out. But at WOT that's not that bad.
Yes
Unplug the pedestal. If it still makes the noise the buy a used set of up pipes on here that are the bellowed style (no gaskets to wear out). Seen a guy has three sets on here. New they are $400+
What kind of turbo is on a 7.3? Isn't it just waste-gated? Could it be the waste-gate stuck open? Also, a leak between the manifolds and the turbo could very well create a big loss of boost. Maybe you should check into that waste-gate at the same time you get that pesky leak dealt with along with that EBPV. Anyone agree...?
Finally got around to it all.... Big leak at the collector in my drivers side up pipe (literally the pipe fell out of the collector when i pulled it out without loosening the clamp.)
EBPV was also partially stuck.
I replaced my up pipes with the IH bellowed up pipes, installed a highflow ebpv delete turbo outlet and pedestal, and also installed a wicked wheel 2, and deleted the Air Intake Heater (AIH).
The truck is running GOOD. Even made the tranny feel better. I ran it last night after it was all back together and pulled 23 PSI The new WW2 sounds awesome, and overall the truck sound much better.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
