no start sometimes - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2008, 01:11 PM Thread Starter
scotty2280's Avatar
no start sometimes
this post is for a buddy that has a 99/ 7.3. last week he went to go amd start it after work and it wouldn't start so i checked his fuel filter and looked it over but im not that familiar with the 7.3. so he let it sit for about a half an hour and it started right up it's been doing this a couple of times anyone have any ideas where to start looking? its completely stock and has a newer alt and starter. when it doesn't start it just keeps cranking over sounds like there is enough juice. has me puzzled , any help would be appreciated thanks
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #2 of 6 Old 03-27-2008, 01:19 PM
Desert Shield/Storm Vet
vitalidle's Avatar
No other issues with it stalling while running only hard starts or no starting?
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 6 Old 03-27-2008, 01:38 PM Thread Starter
scotty2280's Avatar
yep no other issues
post #4 of 6 Old 03-27-2008, 01:41 PM
vitalidle's Avatar
Does he have a way to scan the truck? I guess start with the easy stuff first and check all connections make sure they are tight on the batteries and corrosion free. After that he may want to check the glow plug relay maybe that is working intermittenly.
Auto 93,000 miles
DP Tuner F5
post #5 of 6 Old 03-27-2008, 03:45 PM Thread Starter
scotty2280's Avatar
how do you check the glow plug relay?
post #6 of 6 Old 03-27-2008, 04:25 PM
vitalidle's Avatar
Troubleshooting GPR & GP's
Auto 93,000 miles
DP Tuner F5
