...Play and looseness in steering???? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-25-2008, 04:00 PM Thread Starter
krupatex's Avatar
Angry ...Play and looseness in steering????
I've got about 3in. of looseness and play in my steering wheel???? 2000, 250 has 215,000 miles on it so I'm sure this has a lot to do with it. Should I start with steering box and go down the lin to the steering arms or should I check the steering wheel shaft for wear???? If yes.... how in the hell do I do that???? HELP, IT'S DRIVING ME CRAZY!!!
MY STEERING
-2000, 7.3 F250 4x4 LB-
2" Suspension Lift
Straight pipe exhaust (NO Kitty)
FLAT BLACK 6"STACK!!!!!
ZOODAD
CCV MOD
Waste Gate delete
DIY Tymar air filter system
AGR Ford Super Pump
Front Sway Bar Quick Disconnects (ARTICULATE LEAFS!!)
..."Texan born and bred".....
-Weatherford/Fort Worth-
krupatex is offline
post #2 of 22 Old 03-25-2008, 04:26 PM
i am in the same boat. i'm outta ideas too
I'm a wh0re for free stuff
kinghawg98 is offline
post #3 of 22 Old 03-25-2008, 04:34 PM
peterf.'s Avatar
the stering box has an adjustment screw my mechanic adjusted foer me not shore how its done
peterf. is offline
post #4 of 22 Old 03-25-2008, 06:32 PM
marc9441's Avatar
mine was doing that took it in they said upper and lower ball joints.it was expensive thats all i remember
2002 f350 c/c lb 4x4
afe stage 2 pro guard 7
superchips tuner
4" straight pipe 5" tip
zoodad mod.
foil delete
new valve body and convertor
dent in front bumper from wife
1995 f350 standard cab 4x4 193,000
diy intake
fpr shimmed with gauge
3" dp into 4" straight pipe with 5" tip
train horns soon!!!!
2000 excursion limited
superchips tuner
afe stage 2
4" turbo back
4" lift on 35s
marc9441 is offline
post #5 of 22 Old 03-25-2008, 07:44 PM Thread Starter
krupatex's Avatar
I'm also hearing a lot of shaking and rattleing when I go over a bump or bumps. I know the 3/4 tons are rough riding and all, but there sure seems to be alot of noise (rattleing) coming from under the front end. I just want to tighten things up, if possible, and try and get back what's been shook loose in the past 200k miles.
2" Suspension Lift
ZOODAD
CCV MOD
Waste Gate delete
AGR Ford Super Pump
krupatex is offline
post #6 of 22 Old 03-25-2008, 07:45 PM Thread Starter
krupatex's Avatar
did they replace your ball joints????
2" Suspension Lift
ZOODAD
CCV MOD
Waste Gate delete
AGR Ford Super Pump
krupatex is offline
post #7 of 22 Old 03-25-2008, 09:08 PM
Peppy's Avatar
to check the steering box have a friend move the steering wheel very slowly until the freeplay is taken up back and forth while you are looking at the pitman arm and if it doesn't move then the steering box is loose, to adjust this you have to remove the air filter driverside battery and tray and intercooler to intake pipe, now on the top of the steering box there is an adjusting screw and lock nut it requires an allen wrench and if i remember right a 5/8 (16mm) wrench, back off the lock nut 1/2-1 turn then slowly turn the adjusting screw in till you feel it bottom, don't force it once it bottoms hold it there and lock the locknut, although it sounds complicated it shouldn't take more than 30-45 minutes i had to do this on my 04 f-350 at 80,000kilometers P.S. make sure your wheels are straight ahead when you do this
Last edited by Peppy; 03-25-2008 at 09:10 PM. Reason: forgot to add important note
Peppy is offline
post #8 of 22 Old 03-25-2008, 09:32 PM Thread Starter
krupatex's Avatar
awsome... I think I'll check it out for sure. thanx
2" Suspension Lift
ZOODAD
CCV MOD
Waste Gate delete
AGR Ford Super Pump
krupatex is offline
post #9 of 22 Old 03-25-2008, 09:48 PM
tonyf250's Avatar
Did you put on an aftermarket drop pitman arm. If so you may need to tighten the nut up on the steering box. mine was loose and I had to torque it to 350 ft lbs.
'05 F-250 CC 4x4 6.0
6" Fabtech lift
BANKS exhaust
Airaid intake
SCT tuner
w/Matt's tunes!
Auto Meter Pro-Comp Ultra-Lite boost,pyro,tranny
A-pillar gauge mount
Zoodad
mod
35"x12.50"x20" Mikey Thompson Baja ATZ's
20"x10" MotoMetals
tonyf250 is offline
post #10 of 22 Old 03-25-2008, 11:00 PM
Addicted to Diesel
cowboyupamrka's Avatar
Send a message via AIM to cowboyupamrka Send a message via Yahoo to cowboyupamrka
i did the adjustment in my steering box but you should be able to see it on top of the steering box on your truck without removing anything. right off to the side of the battery box and intercooler pipe. it is easy to see with light. allen wrench and wrench is what you will need.
2000 F-250 CC SB
300K MILES, HEAVY DUTY 4R100 W/ AFTERMARKET COOLER (HAVE 6.0 COOLER, NEED TO INSTALL)
TW CHIP
BOOST, PYRO, TRANNY TEMP, AND FUEL LEVEL
4" TURBO BACK, S&B W/ ZOODAD
B&W GOOSENECK HITCH, COBRA CLASSIC 29 NW
315/75 R16 BFG A/T, 350 REAR BLOCKS, 3" HANGER KIT FRONT
ITP OVERBOOST, CCV MOD, HPX, CCK
RECON SMOKED TAIL LIGHTS & CAB LIGHTS W/ WHITE LEDS
cowboyupamrka is offline
