Massive Oil leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-24-2008, 06:16 PM Thread Starter
PwrStrkd73's Avatar
Massive Oil leak
I just installed a CCV mod and now there is massive oil coming out of the turbo pedestal. There'd been an oil build up in the intake valley for a while now and the pedestal has oil gunk dried on it, so I think it's just coincidence that it started really gushing now. I unplugged the CCV mod hose by the air intake and it was blowing freely, so I really don't think that's the issue. The only other thing I did was clean and re-tighten the intercooler pipes and boots while installing the CCV mod. We were backing out of the driveway after the CCV mod and intercooler pipe cleaning when my wife noticed a huge pool of oil where the truck was parked at, so I didn't drive the truck at all after the CCV mod / intercooler pipe cleaning.
I spent a long time laying on the motor today with a extendable mechanics mirror and a flashlight, then I ran it and waited for the oil to start leaking badly. It doesn't come out until the truck starts to warm up, like about 3-5 minutes, then it really comes out. The previous owner took the EBVP off when he installed a new turbo b/c it stuck closed and burnt the original turbo up. So, there's a hole with a bolt stud coming out of it about halfway up on the right side of the pedestal that can be seen on the right (passenger side) below the exhaust side of the turbo. At first I thought the oil may be running off the top of the pedestal, but I'm almost 100% sure it's actually coming out of that hole. Could someone PLEASE give me some guidance on this? I don't know what could be causing this. If the O-rings were bad wouldn't the oil just leak from the top or bottom and not come out a hole in the middle of the pedestal?
Update.... I think I've just found the problem. I found the fantastic attached picture courtesy of the tech files here on how to diagnose a 7.3L oil leak. The oil is coming out of the housing where the red writing says Exhaust Back pressure rod on the turbo pedestal.
If this sounds reasonable, what's my next step? Get a pedestal without the EBVP (since my turbo doesn't have the EBVP anyway)? If so, where's a good place to get them?
2000 F-250 7.3L PSD, 6-Speed, 131.5K+, 4-Puck button clutch, Western Diesel~ Tri-Power Chip- Update: now TSPerf 6pos (Stock,+50,75,140Hp,HighIdle,NoStart), Ram Air, Gauges {Boost & Pyro}, AFE Stage 1, 4" Turbo back exhaust, ITP Over-Boost Eliminator, Cyclone Fan Controller, Shortened Wastegate Rod, 4" Lift, BF Goodrich A/T 35x12.50x16.5, Eagle Alloy Rims, GoRhino Brush Guard, etc. Check it out here~
PwrStrkd73 is offline
post #2 of 5 Old 03-24-2008, 06:19 PM
If it aint a CAT itsa DOG
dieseldan2005's Avatar
Heres a bump for ya. I have a small oil leak on mine. Only drips once in a while, but i want to fix it before it gets worse. Have you taken off the turbo? If so how hard was it?
Diesel Dan
10,000 LAKES CHAPTER MEMBER
2003 F350 Crew cab long box, FX4, 6.0, torqshift, Lariat.
dieseldan2005 is offline
post #3 of 5 Old 03-24-2008, 06:30 PM
International Threat
Marty's Avatar
Originally Posted by PwrStrkd73 View Post
Update.... I think I've just found the problem. I found the fantastic attached picture courtesy of the tech files here on how to diagnose and oil leak. The oil is coming out of the housing where the red writing says Exhaust Back pressure rod on the turbo pedestal.
Gut and plug your own...
http://www.powerstroke.org/forum/7-3...-pedistal.html
Easy... here's the writeup for that.
http://www.powerstroke.org/forum/7-3...oring-rnr.html
http://www.powerstroke.org/forum/7-3...o-7-3-psd.html
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #4 of 5 Old 03-24-2008, 06:32 PM
thanks marty!
Diesel Dan
post #5 of 5 Old 03-24-2008, 06:39 PM Thread Starter
PwrStrkd73's Avatar
Yeah, thanks Marty. I LOVE the tech files here!! Where has this site been for the last 2 years I've owned my PSD!! That made my night. I've been down in the dumps the last 2 days over this, mostly not knowing what was making the oil leak or where it was coming from, but now with a little work the pedestal should be leak free. With that and the CCV mod I should FINALLY have a nice clean engine. Well for the most part anyway!!! THUMBS UP TO YOU GUYS!!!
